Old 4/6/08, 2:06 PM
Kenneth R. Malone Kenneth R. Malone is offline
Default Bonding Screw
Should I report an incorrect bonding screw? I found a new upgraded panel with what looks like a sheet metal screw used as the bonding screw. The green bonding screw with tag was laying in the bottom of the panel. Ken
Old 4/6/08, 2:12 PM
David P. Valley's Avatar
Default Re: Bonding Screw
In this case, a bond is properly installed. Even if an improper screw was utilized, the bond is still going to be effective. IMO...I wouldn't call it out.
Old 4/6/08, 2:43 PM
Unmoderated Guest
From a code standpoint that is quite illegal and NOT acceptable.
Old 4/6/08, 3:02 PM
Would you please expand.
I had no idea that a green screw is so different from a regular screw.
Old 4/6/08, 3:13 PM
tdietrich1's Avatar
1. per NEC - "Sheet metal screws shall not be used to connect grounding conductors to enclosures. "
and
2. Manufacturer's supplied screw(or similar) might be the only ones used during testing. So read the card attached to the green screw, sine MI could be violated. L&L issue.
tom
PS, now if it's a drywall screw, that might be ok per #1. However still a L&L issue.
Old 4/6/08, 3:14 PM
and
tom
So what sort of material is the manufacturers bonding screw?
Old 4/6/08, 3:15 PM
tdietrich1's Avatar
Identified and tested materal.
Old 4/6/08, 3:16 PM
Gee, that helps...Thanks
Old 4/6/08, 3:18 PM
tdietrich1's Avatar
BTW, I still do electrical work, for free, and carry a green sharpie too.
Old 4/6/08, 3:20 PM
A green sharpie will definitely work on my inspections.
Old 4/6/08, 3:22 PM
I guess, I have to agree with David on this one, some things just don't seem to make any common sense, even though it is code.
Marcel
Old 4/6/08, 3:28 PM
Marcel
Will this work?
It's a patented (by the manufacturer - me) two in one screw.
Use it in the panel as a bonding screw (after using the green sharpie on the head of it) and then go on the opposite side of the wall and you've got yourself a handy dandy coat hanger.
Old 4/6/08, 3:31 PM
Marcel
The requirement for the a green MBJ screw goes back to the early 90"s when an Inspector from Portland, OR sent in a proposal, because the existing panelboard neutral bars then had a screw but it was silver like the others, so with that we got the GREEN screws, the sheet metal screw business started during a change made in a later code because the proposal indicated that it was unreliable.
I believe that Home Inspector's should rely on the comments made by those here with many years of experience and listen to them.
THE SHEET METAL SCREW IS A VIOLATION!
Old 4/6/08, 3:34 PM
David:
What size in AWG is this screw?
What if the service entrance conductors were 3/0 AWG copper, would it be large enough? What is the purpose of the MBJ?
Old 4/6/08, 3:35 PM
Thank you Joe, but what is this green bonding screw made out of?
Neutral bus bar failed inspection Greg Moritz Electrical Inspections 18 1/19/08 2:53 PM
Subpanel Bonding Screw away Electrical Inspections 24 1/9/08 3:46 PM
Demystify Grounding & Bonding Class pabernathy Inspection Education & Training 5 12/24/06 2:10 AM
Is the there a 'bonding' screw that I don't see. mgault Electrical Inspections 9 10/13/06 11:31 AM
