Square D service equipment, green bonding screw?
Where's the grounding electrode conductor? No grounding electrode. Anything else? Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It's difficult to tell from your picture if the bond screw is present or not, but I guess you say it's not there.
I can't tell from the pictures if, perhaps, the grounding electrode conductor lands in the meter pan or not. That's possible, and compliant if that's the case, although some power companies aren't especially excited about that. The grounding electrodes may be present, but buried. Having said all that, you may be 100% right in saying that the grounding electrode system is completely missing. Just can't tell from the pics, myself. The panel change is a bit sloppy, which is what makes me think this was homeowner/handyman work and the GEC is missing. That's simply not the type of work an actual electrician would have done. We'd have brought all those cables in the top of the panel, and none in the sides. There may be some supporting/securing issues with the new romexes, particularly the new #10 run in the left side. The tripped breaker also concerns me to the extent that I'd want that circuit investigated. Last edited by Marc D. Shunk; 4/27/11 at 6:41 AM.. |
It's good to see you here again Mark. Welcome back.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
It would connect to the neutral in the meter base. A connection in the panel would therefore not be required. |
In this scenario would/could the grounding electrode be at the service/transformer. No ground rod or grounding at water pipe present. Also would the neutral/ground bar still need to be bonded to service panel? Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
The grounding electrode condcutor (GEC) is permitted to be connected to the neutral at any point between the service drop and the service disconnect. Any connection before the service drop, although permitted, would not satisfy this requirment.
Thanks again.
| Proper CSST bonding | sfogarty | Plumbing Inspections | 25 | 1/3/11 1:54 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
