Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
Old 9/9/07, 3:16 PM
gmckenzie's Avatar
gmckenzie gmckenzie is offline
Send a message via Yahoo to gmckenzie
Default Breaker questions?
I'm still learning, so I wanted to get some opinions and explanations about this 125A panel in my future brother-in-law's house. Ignoring the double taps, the neutrals bonded with gound, the frayed wiring, the dust buildup, broken conduits and several other things in the background, my question centers on the 30A breaker in the upper right hand corner. It apparently feeds a sub panel that contains the breakers for the AC and heater. It is rigged so that the inner switches can be operated independantly of the outer swiches and vise versa. Also, if you trip the top switch, all four switches trip. I've never seen a breaker that operates like that. Any information would be helpful. Thanks
Old 9/9/07, 6:57 PM
Marc D. Shunk's Avatar
Default Re: Breaker questions?
That breaker is called a "quad" in electrician trade slang. It's like four tandems connected together. Some have the two inner breakers handle-tied to make a 220 breaker in the middle, and have two singles on each side. Others have the two inners tied and the two outers tied, making two double pole breakers. It's a space saving thing for an already jam-packed panel. They're a little bit pricey as well. They're certainly not a truck stock item for most electricians.
Old 9/9/07, 7:03 PM
Jeffrey R. Pope's Avatar
240V circuits are tied together (each leg of 120V) so that all power is cut when a breaker trips (opens). These "mini" breakers are powering two appliances with 240V each. Think of it as four 120V circuits from only two "stabs" on the bus bar.
Ignoring the neutrals bonded with gound
Neutrals are required to be bonded to the GEC at the service equipment.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/9/07, 7:05 PM
Oops. Marc beat me to the punch. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/10/07, 1:34 PM
gmckenzie's Avatar
Thanks. That also adds credence to the idea that the breaker is feeding the sub panel that is controling the AC and heater - one 240V for each.
Electrical Guru Question? Breaker lock outs pdoane Electrical 4 9/7/07 3:05 PM
Double Tapped Breaker tjohnson3 Electrical 8 4/20/07 10:04 AM
AFCI Questions and Answers - Mike Holt pabernathy Electrical 0 7/7/06 1:24 PM
Some good questions that always need answers jtedesco1 Electrical 5 6/16/06 10:10 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
