Would a breaker with a lockout be OK for installation under the latest NEC for an airhandler installed out of view of the panel with no other disconnect except in the unit?
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Without looking it up, I'd say yes. It is OK to do a water heater that way.
Yes,
Why the Lockout (LOTO) would be Present. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I thought they were going to do away with that in favor of in sight disconnects. New construction today I was just double checking, I don't have a copy of the NEC for the 2007 Fl. code and revision.
Yes, unless changed. Happened to me about 7 years ago building a school cafeteria kitchen and we had no room for the 200 amp disconnect for the water booster in the kitchen.
Electric inspector allow us to have a lockout tag out breaker on the main panel. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I am only Referencing what I know
from Commercial Industrial Petrochemical Work LOTO at the Source with Lock of Contactor and Each Individual Working Company Lock can only be removed after all others Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
If the disconnect is within the unit then nothing else is required.
Robert, I have always seen a disconnect with the Air handlers, is that a specification item by the engineer or just standard by the manufacturers?
Yes I am familiar with them. Always took it for granted that a disconnect is on the unit. I have seen in instances, depending on the equipment, that a disconnect is mounted on a pedestal near or on the unit also.
A service outlet is always required also. WP Thanks LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I beg to differ with you on this, I would not approve it without the lockout on the breaker since the circuit would be active through the frame and the internal connections not visible. I would have preferred that a seperate pull type or breaker or even a switch be installed as a disconnect within view of the unit so that sevice personell could be certain the power could not be turned on. Code or not.
http://www.osha.gov/SLTC/controlhaza...rgy/index.html
If having employees.... essential to be familiar with... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Rollie Meyers is a non-member guest and is in no way affiliated with InterNACHI or its members.
That would not qualify as a disconnect since there is no means to lock it out, it is just a switch..
The locking provision is if it's not within sight of the equipment. A unit switch on or in the equipment does not require a locking means. Same thing would apply to a disconnect within sight of the equipment, no locking means required. |
| Siemens recalls circuit breakers due to fire hazard. | gromicko | Electrical Inspections | 3 | 9/24/10 7:36 AM |
| Main panel...recommendation ? | dnasser | Electrical Inspections | 6 | 11/22/09 9:55 PM |
| Counterfeit Breakers | jallingham | Electrical Inspections | 0 | 5/27/08 4:25 PM |
