Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
Old 6/12/09, 12:38 PM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is online now
Default Bundling wires at panel
What is the rule for this? Is it only three wires per cutout through the top of the panel? I know this is wrong but do not know what the exact requirement is.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America)
Old 6/12/09, 3:30 PM
Jim Port Jim Port is offline
Default Re: Bundling wires at panel
Try 312.5(C). Cables to be secured to enclosure.
Old 6/12/09, 6:56 PM
Is that NEC cause 06 IRC does not have a 312.5(C)
Old 6/12/09, 7:33 PM
Sorry,
Yes, that is NFPA 70 or the NEC.
Old 6/13/09, 11:59 AM
Paul W. Abernathy's Avatar
Send a message via AIM to pabernathy Send a message via MSN to pabernathy
in addition to 312.5(C) of the NEC , Mr. Port is 100% correct but I figured it would be an EXCELLENT time to show the exception to that requirement as well.......just in case you guys ran into this situation regarding a surface mount application like the one above. ( This exception does not apply to the picture shown....)
Exception: Cables with entirely nonmetallic sheaths shall
be permitted to enter the top of a surface-mounted enclosure
through one or more nonflexible raceways not less
than 450 mm (18 in.) and not more than 3.0 m (10 ft) in
length, provided all of the following conditions are met:
(a) Each cable is fastened within 300 mm (12 in.),
measured along the sheath, of the outer end of the raceway.
(b) The raceway extends directly above the enclosure
and does not penetrate a structural ceiling.
(c) A fitting is provided on each end of the raceway to
protect the cable(s) from abrasion and the fittings remain
accessible after installation.
(d) The raceway is sealed or plugged at the outer end
using approved means so as to prevent access to the enclosure
through the raceway.
(e) The cable sheath is continuous through the raceway
and extends into the enclosure beyond the fitting not
less than 6 mm (1.4 in.).
(f) The raceway is fastened at its outer end and at
other points in accordance with the applicable article.
(g) Where installed as conduit or tubing, the allowable
cable fill does not exceed that permitted for complete conduit
or tubing systems by Table 1 of Chapter 9 of this Code
and all applicable notes thereto.
AGAIN.....this does not apply here in your picture BUT good information to remember when you are doing those HI inspections on a panel in an unfinished basement and so on.
Paul W. Abernathy,CMI,CEI,CEPE
NECŪ Consultant/Columnist
www.twitter.com/ElectricalGuru
- ICC & IAEI Certified Electrical Inspector
- ICC & IAEI Certified Electrical Plans Examiner
- Look for my article in the Nov/Dec 2009 IAEI Magazine
- 2007 "Top Gun" Winner - Mike Holt Enterprises
" visit www.TheElectricalGuru.com Today !"
National Electrical Code Information and Discussion jtedesco1 Electrical 44 4/18/08 12:43 AM
Ground Wires Inside a Panel mveitenhans Electrical 13 10/29/06 12:39 PM
Panel Inspection Safety roconnor Electrical 10 9/24/06 10:02 PM
Bad electrical problem Pest Guy Electrical 4 1/20/06 10:26 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
