Old 2/14/11, 1:50 PM
Marc A. Goldenberg Marc A. Goldenberg is offline
Exclamation Busbar & connectors painted over
Upon removing the interior circuit breaker panel cover, I occasionally have observed the busbar, connectors & bare wiring painted over.
The NEC code calls for total replacement of the panel, simply taking apart the panel & removing/cleaning the paint & reassembling is not recommended.
Does anyone have any info or a link about this type deficiency?
THANK YOU & BE SAFE!
Marc A. Goldenberg
State License # HI1365
All Tropic Home Inspection Services
www.alltropic.com
busbar-and-connectors-painted-over-busbar-and-connectors-painted-over.jpg Connectors  Painted Over.jpg
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/14/11, 2:07 PM
Mark S. Tyson Mark S. Tyson is offline
Default Re: Busbar & connectors painted over
Marc A. Goldenberg
www.alltropic.com
Marc,
I can't hep with ant links but was hoping to get more info. from you. In the past i have built projects through out Palm Beach county and in my experiance the electrical inspectors would never let something like that fly. I was curious judging from the size of the panel pictured I'm guessing that is either a condo. or an apartment. If that is the case i wonder if the builder hired a private inspection company because most of the county electrical inspectors are ball busters
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Old 2/14/11, 2:21 PM
Originally Posted by mtyson View Post
Marc,
Thanks Mark.
This was in a Boca Raton condo built in 1970.
Sometimes I find it in single family homes less that 10 years old.
Old 2/14/11, 5:05 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Right in the NEC:
110.12 Mechanical Execution of Work.
Electrical equipment shall be installed in a neat and workmanlike manner.
FPN: Accepted industry practices are described in ANSI/NECA 1-2006, Standard Practices for Good Workmanship in Electrical Contracting, and other ANSI-approved installation standards.
(A) Unused Openings. Unused openings, other than those intended for the operation of equipment, those intended for mounting purposes, or those permitted as part of the design for listed equipment, shall be closed to afford protection substantially equivalent to the wall of the equipment. Where metallic plugs or plates are used with nonmetallic enclosures, they shall be recessed at least 6 mm (¼ in.) from the outer surface of the enclosure.
(B) Integrity of Electrical Equipment and Connections. Internal parts of electrical equipment, including busbars, wiring terminals, insulators, and other surfaces, shall not be damaged or contaminated by foreign materials such as paint, plaster, cleaners, abrasives, or corrosive residues. There shall be no damaged parts that may adversely affect safe operation or mechanical strength of the equipment such as parts that are broken; bent; cut; or deteriorated by corrosion, chemical action, or overheating.
Old 2/14/11, 6:47 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by Robert Meier View Post
Right in the NEC:
It wasn't until the 1990's that this was mentioned in the NEC. Before this the code just stated "equipment shall be installed in a neat and workmanlike manner."
That being said I always recommend replacement of the affected components when paint or texture is on the interior of a panel.
www.MauiHomeInspections.com
Old 2/14/11, 7:12 PM
Joe Funderburk, CMI's Avatar
That panel is the worst I have ever seen.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 2/14/11, 7:33 PM
I've always viewed neat and workmanlike as unenforceable since the phrase isn't defined anywhere in the NEC and is completely subjective.
Old 2/14/11, 7:38 PM
Curtis M. Vilt's Avatar
Curtis M. Vilt Curtis M. Vilt is offline
There is a definition for "Professional workmanlike manner". I am looking for it.
Strong-Drive® SD Screw for Structural Connectors jjonas Structural Inspections 4 12/23/09 5:04 PM
Gas Connectors Recalled ldapkus General Inspection Discussion 1 3/4/08 8:32 PM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
AMP (Tyco) Copalum connectors Steven Brewster Electrical Inspections 25 5/5/06 9:18 AM
