wants to know if this outlet is ok like this?
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The box may or may not be properly supported, depending on the raceway type. It's hard to tell from the photo. Two entries of rigid conduit threaded wrench tight is permitted as a box support. (Although I think that I see a set screw type EMT connector).
I would suggest upgrading the cover. Does it have GFCI protection?
Yep
Flaps facing sideways and though not often called out is supposed to have a plastic shield for covering ,when a extension is plugged in. |
In-service cover and GFCI if not already.
Hi, Im a new inspector.
I noticed several things about the outlet. The box is not properly supported. You can't support it with only the raceway's. I would suggest an In-Use cover Make sure it is GFCI protected. Is that a PVC or EMT raceway going into the ground? If EMT it will rust. |
Why would an electrician have to ask about an outlet? Shouldn't he know?
He's possibly coming from a different area and doesn't know what Tucson, AZ allows...
Thank you all for your info and help...
WARNING THREAD DRIFT...
What was the deal with the blue masonite wall. Looks to be masonite in direct contact with the ground. Also the wall appears to be inset on the slab and appears to rely on a caulk joint as flashing. Was the slab height higher behind it? Were there signs of water seepage? Foxe Smothers ( Owner / Inspector ) Pelican State Inspection Your Best Choice for Home Inspection in the Shreveport & Bossier City Area! www.PelicanState.Net www.ShreveportHomeInspector.net www.BossierCityHomeInspector.net foxe@pelicanstate.net LSBHI #10399 |
Very common out here. The t111 just gets wet and falls apart. Nothing showed inside.
| libility question | Jay Moge | Electrical Inspections | 24 | 1/16/06 12:43 AM |
| Answer to a common question about GFCI's | jtedesco1 | Electrical Inspections | 4 | 1/12/06 10:29 PM |
