Old 3/18/07, 10:48 AM
rschlater rschlater is offline
Default Buzzing lights
I just did a HI on a home that was built in the early 60's. Thje home has been added on a couple of times. I found a breaker box in the bottom kitchen bar cabinet, one in the closet, one in the garage, and one in the basement. The wiring was a mess I suggested that they contact an electrical contractor for an evaluation. However, in the original part of the home, there were lights that would buzz when you would turn them on and off. Is there a resister or something in this lighting system. Need some help identifing this. Never ran accrosed it before.
Thanks
Bob
Old 3/18/07, 11:20 AM
John J. Passailaigue, Jr.'s Avatar
John J. Passailaigue, Jr. John J. Passailaigue, Jr. is offline
Send a message via AIM to jpassailaigue
Default Re: Buzzing lights
State that a strange noise was being heard durring the inspection when some light switches were activated. The electrician should investigate it further.
John J. Passailaigue Jr.
NACHI05062580
Auburn Home Inspection
Auburn, Alabama
WAR EAGLE!
Old 3/18/07, 11:41 AM
rromoser's Avatar
rromoser rromoser is offline
FYI. 100 watt light bulbs are notorious for buzzing when controlled by a dimmer that is set to just the right (wrong) spot. The filaments vibrate. Rough service lamps that have extra filament supports will help.
Old 3/18/07, 1:55 PM
The lights don't buzz after it is turned on, only when you turn on the switch. It is a push button switch. It almost sounds like a door bell buzzer but not as loud.
Old 3/19/07, 8:17 AM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Aluminium single strand distribution wire , that needs attention, might do that!
Refer to a qualfied electrician!
Cheers
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Old 3/19/07, 8:49 AM
John W. Springstead's Avatar
John W. Springstead John W. Springstead is offline
Sounds a bit like "low voltage" lighting to me, which was used a bit in the 60's around here.
John Springstead
Home Inspections of USA
1752 N.E. Torch Lake Dr.
Central Lake, MI 49622
1-231-544-8016 office
1-231-544-6001 fax
www.homeinspectionsusa.us
Old 3/19/07, 11:02 AM
Paul W. Abernathy's Avatar
yeah..it sounds like what John stated to me as well.....if it were dimmers on the system....cheap dimmers can make a filament BUZZ but if you have an old push button switch...check in the attic to see if the lighting is an old magnetic solinoid lighting system.....worth a look see....
Paul W. Abernathy,CMI,CPI,CME
Old 3/19/07, 6:00 PM
That's kind of what it sounds like is a soliniod kicking on and off. I'll check it out to see if I can get to it from the attic. Thanks
Old 3/19/07, 7:04 PM
tdietrich1's Avatar
Originally Posted by rschlater
The wiring was a mess ... there were lights that would buzz when you would turn them on and off. Is there a resister or something in this lighting system.
Photos of this 'mess' would close the case on 'low voltage' controled lights.
tom
Old 3/23/07, 11:40 PM
The reason I posted this question was because I had the oppertunity to inspect the same home twice, by two different clients. I inspected this home about 3 months ago, and I put in my report that should contact a licenced electritian. These same people hired me agian to inspect a different home for them. They said that they had an electritian look at the first home, and said the the home should be rewired because he wa kinding voltage drops in several circuits. The home had been added on to several times and had a sub panel for each time. I posted this question before I inspected the home for the second time. After taking in all of you guys input, I found out that you guys were right on the money. It was a low voltage system running the lights in this home. Thanks for all of the responses.
Bob
Old 3/24/07, 11:09 PM
Excellent....see....we are not all QUACKS...lol........
Now the electrician saying the house should be rewired because of voltage drop...well....I will reserve my comments on that since no percentage was stated and I will give the electrician the benefit of the doubt...lol
Lights Flickering while appliances start-up and while running. Jeff Nunz Electrical Inspections 15 11/27/07 5:04 PM
Buzzing noise from panel cbrands Electrical Inspections 6 5/30/07 2:00 PM
Lights & GFCI Outlets thejnicki Electrical Inspections 14 2/28/07 4:48 PM
outlets and lights question Scott Schultz Electrical Inspections 4 1/27/07 8:59 PM
