Did an inspection today on a home that was built around 1940 had BX cable (cloth sheathing) no ground. I have not seen this type very often. Other then non grounded outlets is there any concern with this wiring. Thanks in advance.
John Zirzow Homestead Inspections llc Eagle River, WI 54521 715-479-4151 |
| Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
AC cable (Armor Cable) is the known by the trade name BX.
I believe the cloth cable is Old Romex. Trades referred to it as rag wrap romex. Breaks down from excessive heat and rodents like it. Any pics of the wiring? Last edited by dmacy; 1/11/11 at 7:39 PM.. |
As David said photo's would be helpful. If the outer jacket is not metallic then I agree with David that you probably have NM cable with no ground which is probably getting near the end of it's life expectancy.
BX and Armored cable are similar but not the same. BX is no longer is use/manufactured. AC is currently what is used.
David Hays All Points Home Inspections LLC Denver, CO 720-670-0366 allpointshomeinspect@yahoo.com www.allpointshomeinspections.org |
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 Last edited by mcyr; 1/11/11 at 8:15 PM.. |
I think I did this right still trying to figure this stuff out.
Yup, that's type AC cable, AKA BX. Most likely that the conductors are rubber insulated, tinned copper.
| Short circuit failures with 12/3 NM-B cable and NM clamp connectors | pabernathy | Electrical Inspections | 10 | 4/17/11 1:43 PM |
| Commercial Electrical Inspections | jtedesco1 | Commercial Inspections | 29 | 1/12/08 5:03 AM |
| Did you KNOW this about NM Cable? | pabernathy | Electrical Inspections | 0 | 12/19/06 8:46 AM |
| Ceilings falling with wires in it. | jsmith3 | Interior Inspections | 9 | 3/16/06 7:24 PM |
