Old 12/17/09, 3:42 PM
David K. Lee David K. Lee is offline
Default A/C Circuit Breaker
I find this quite often and wondered if you are finding this also. On the air conditioning unit the data plate said recommended breaker size-40 amps. Maximum breaker size 40 amps. The breaker in the service panel is only 30 amps which is undersized. Many times I find units labeled for a 20 amp breaker on the data plate and 30 amp in the panel. I write it up every time. Anybody else see this or am I missing something?
Find an InterNACHI certified Wyoming Home Inspector (and anywhere else in North America)
Old 12/17/09, 3:53 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: A/C Circuit Breaker
Which of these concerns you (you asked about both)?
Max breaker (per data plate) of 40A and a 30A in the panel.
No issue here.
or
Max breaker (per data plate) of 20A and a 30A in the panel.
Write it up
Old 12/17/09, 3:56 PM
Jeffrey R. Pope's Avatar
There is a minimum circuit ampacity and a maximum allowable circuit breaker size.
The breaker size is not allowed to exceed the maximum capacity requirement, but it does not necessarily need to meet the max. size.
The minimum tells you what the minimum conductor size needs to be, even if the breaker is oversized for the conductor.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/17/09, 3:59 PM
Jim Port Jim Port is offline
Unmoderated Guest
No issue here. Agree
or
Write it up unless the proper size is in the disconnect
Old 12/17/09, 5:17 PM
Thanks for the advice
Old 12/18/09, 12:40 AM
David,
Just make sure the MCA is a conductor that can handle the MCA listed and make sure that on the MOP does not exceed the listing given.
MCA : 28A ( would install a 10 AWG )
MOP : 40A ( would install a 40A or less breaker/fuse if it will hold )
It would also be important to remind everyone that IF the AC Compressor says "Fuse Only" then fuses must be in the system. Either at the panel or a the units disconnect. This does not mean the disconnect at the AC Compressor is required to be fused at all as it can be non-fused ( simple pull out ) but let say the nameplate says "Fuse Only" and you have a circuit breaker in th electrical panel...how would you comply. Simply change the non-fused disconnect to a fused disconnect and it would be compliant.
Just a tidbit of additional information.....in brief form.
Paul W. Abernathy
Old 12/18/09, 12:47 AM
rmaday's Avatar
Paul, on this topic, why can the conductor sizes for AC units vary from the common 14 AWG for 15 A breaker, etc?
I know the proper answer is "because the manufactiurer says so", but why!?
TIA
Old 12/18/09, 1:55 AM
Paul Pendley Paul Pendley is offline
Start up if I remember right.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 12/18/09, 7:18 AM
Unmoderated Guest
Rick, wire sizing for AC are sized based on Article 440. The OCP is to allow the compressor to be able to start without tripping the breaker. This is a short term event. The wire is sized for the running current of the unit which is less than what is used at startup.
Old 12/21/09, 8:12 PM
Jim...is your name Paul....lol.....just kidding fella......Answer Away
Paul W. Abernathy
Old 12/21/09, 10:14 PM
Unmoderated Guest
I'll leave you the tough ones for the Guru site.
Old 12/21/09, 11:18 PM
lol.....Aint no tough ones over there......
Paul W. Abernathy
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Article 240 : Overcurrent Protection Article pabernathy Electrical Inspections 0 5/23/07 11:40 AM
