Old 2/28/07, 6:34 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Default Cable in chimney chase
Are cables allowed in chimney chases? It would seem that hte heat would exceed the insulation temperature rating. I couldn't find anything in the NEC. Any thoughts?
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Old 3/2/07, 12:24 AM
Default Re: Cable in chimney chase
It depends on the flue pipe. If this is triple wall it can be in contact with combustibles and it will probably be fine with the wire.
Old 3/2/07, 10:02 AM
Bill Smith's Avatar
Thanks Greg.
631-434-5200
Old 3/2/07, 10:37 AM
wward wward is offline
Please Note: wward is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think with a 2 inch clearance you are good!
don't bet the farm on my openion!
Old 3/2/07, 12:19 PM
Jeffrey R. Pope's Avatar
Other components can share a chimney chase (piping, cable, conduit, etc.), but the chimney and chase require fireblocking.
You should not be able to see down the chase. It should have a steel or drywall fireblock in place. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/2/07, 9:24 PM
Peter C. Russell's Avatar
Also any wire penetration through the studs should be sealed with fire rated caulking.
Old 3/3/07, 6:22 PM
Bill Smith's Avatar
Excellent points - Thanks guys.
631-434-5200
Old 3/3/07, 8:54 PM
rgiglio rgiglio is offline
If the heating unit is in the basement then as Jeff said a fireblock is required above the boiler or furnace. If your picture however is from the 2nd floor looking down through 1st floor and not the basement than no fire stop is requied. I had the same in my home before I changed to direct vent. You might want to check the town codes too.
Old 3/3/07, 10:04 PM
Firestop is required at every floor and/or ceiling level of a chimney chase. The chase cannot communicate directly with the attic without a firestop.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/3/07, 11:52 PM
Draft stopping and firestopping was not always done back in the olden days.
Old 3/4/07, 1:07 AM
That's true, but it has always been part of the design for manufactured chimneys.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Short circuit failures with 12/3 NM-B cable and NM clamp connectors pabernathy Electrical Inspections 10 4/17/11 2:43 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Cable in Chimney Chase bsmith Electrical Inspections 3 6/10/07 2:04 PM
Did you KNOW this about NM Cable? pabernathy Electrical Inspections 0 12/19/06 9:46 AM
Ceilings falling with wires in it. jsmith3 Interior Inspections 8 3/16/06 8:24 PM
