The main was installed in a bathroom. The panel was recently installed.
When the new box is installed. Lets say in 2004. Is the electrician required to updqate the home to the latest NEC? There where no visible main ground connections, No exterior ground rod. Ect... I know the box isnt allowed to be in the bathroom. It looks like there are some 14 gauge wire to 20Amp breakers. Is the main aluminum wire rated for 100 amps. Looks like #1 or 2. This would be 80 Amps. Any explanation would be appreciated. Would like to also add about how other inspectors note bathrooms that have the older light fixture with receptacle? Am I correct in advising that they remove the old fixture & install a light bar and add a GFCI? Can a 220 line be installed on a board? The one I observed the board was loose. Thanks Dave Paul A. I am looking forward to your class in december. Please make a note that I am attending. I will register soon. |
I've been told by some electricians, they had to do somethings messed up. "had to do", like this situation, the electrician probably had no choice since the service cables came in there, or the bathroom was a diy'er job, and it was originally a small office, or etc, etc, etc. The new electrician was following bad work previously made. I usually respond with, "you could have just walked away".
<walking away shaking head> tom |
Is it safe???????????????
When and code are not something that we want to get into GFCI while not required when work was done but is a very good safety recomendation Look at the whole thing from a safety issue ... Grounding is a safety issue I would pass the whole mess to an electrican --- safety I would not go into NEC or local code at all It might even have been sign off by the local BI -- who knowes rlb |
I dont know how they do it in OHIO, but down here in Florida, they are SUPPOSED to pull a permit for and upgrade (like they ever do), which would require that the box be moved out of the bathroom and that GFCI's be installed. Also, the ceiling in that picture is not sealed.
I would write it up as an improper installation, listing all the defects that you noted, including that my client do a permit search, and recommend repair by a licensed electrician. |
Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
This is an interesting situation.
Up until the 1993 NEC, the panels were permitted in bathrooms. So if this is an upgrade of an existing panel that was approved prior, then the question is would it be required to be relocated when upgraded??? I would call the building department and ask them. But note that the toilet is directly below the panel... that has never been permitted. [110.26(A)] |
And would this be a plumbing violation or an electrical??
Again - lets stay away from code and say is there a safety problem here Yes there is -- and thus call it as same rlb |
acox is a non-member guest and is in no way affiliated with InterNACHI or its members.
But if you can't have the toilet in front of the panel, what are you going to stand on to check it?
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
| Oshawa inspector needed | aspisak | Canadian Inspectors | 1 | 8/16/07 10:10 PM |
| Action needed in NY | jruppert | Legislation, Licensing & Legal Issues for Inspectors | 1 | 6/14/07 10:53 PM |
| Action needed in NY | jruppert | Legislation, Licensing & Legal Issues for Inspectors | 0 | 6/14/07 12:24 PM |
| Volunteer home inspectors needed to help elderly/disabled. | gromicko | Miscellaneous Discussion for Inspectors | 1 | 11/13/06 8:33 AM |
| Greg Bell or someone in Titusville/Palm Bay Florida area needed to do inspections | gromicko | Miscellaneous Discussion for Inspectors | 1 | 7/25/06 3:00 AM |
