Old 7/18/08, 6:17 AM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Default Can anyone tell me when
they started using three wire Romex (grounded) in res construction?
I think I know this but I'm having a senior's moment
Cheers
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Old 7/18/08, 8:59 AM
gbeaumont's Avatar
Default Re: Can anyone tell me when
Cheers
Hi Doug I belive type NM (thermoplastic) "romex" started in the early 1960's
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 7/18/08, 9:19 AM
Regards
Gerry
Hi. Gerry
I found this in http://en.wikipedia.org/wiki/Electri...wiring_methods
About 1950, PVC insulation and jackets were introduced, especially for residential wiring. About the same time, single conductors with a thinner PVC insulation and a thin nylon jacket became common.
Marcel
Old 7/18/08, 9:26 AM
gbeaumont's Avatar
Originally Posted by mcyr
Hi. Gerry
Marcel
Hi Marcel, thanks for that, I knew the "romex" brand started in the 1920's with the rubber and cloth braided stuff, but I didn't know that the thermoplastics started that early, I have never seen in in an unimprooved home built before the early 60's.
I see it mostly from when outlet grounds were required which I think was 1963.
Here's a link to the history of Romex
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 7/18/08, 10:46 AM
Thanks for the Link Gerry.
1922 whow! You must remember that don't you. ha. ha.
Marcel
Old 7/18/08, 11:15 AM
Regards
Gerry
Thanks Gerry... sooooo grounded outlets were first required in 1963?
Cheers
Services Inc.
Whitby Ontario
05021384
Old 7/18/08, 11:56 AM
gbeaumont's Avatar
Cheers
That requirement came in in the 1962 NEC, so was locally adopted in 1963/4 in most cases.
There is a nice history of residential wiring here
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 7/18/08, 3:12 PM
Excellent info thanks Gerry
Cheers
Services Inc.
Whitby Ontario
05021384
Old 7/18/08, 3:18 PM
gbeaumont's Avatar
Cheers
You're welcome, just remember what I have quoted is from the U.S. Canadian code may be a bit different.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 7/18/08, 5:14 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Regards
Gerry
That's good reading! Thanks Gerry.
Old 7/18/08, 5:16 PM
Marc D. Shunk's Avatar
Banned
I don't know about the ground wire itself, but the "reduced ground" went away in 1969. I know I've worked on wiring from the late 50's that had a ground wire in it, but installers often had no idea what to do with it. Regrettably, it was often just cut off flush with the jacket.
Old 7/18/08, 5:43 PM
Regards
Gerry
Hey, I thought you were Brit. all this time.
Old 7/18/08, 7:28 PM
We lived in a house built in 1952-53 PG county, right over the DC line. It had the reduced size ground wire in an asphalt/paper jacket Romex and SqD breaker panel.
My father said it had to do with "GI" inspection. I assume from what I have heard fom around the country, this may have only been enforced near DC.
I know when I bought my first house in 71, the builder said it wouldn't go "GI" (aluminum wire) but by then you could get cheaper financing from a regular bank.
Old 7/18/08, 7:33 PM
gbeaumont's Avatar
I have to admit to having written up a couple of reduced grounds years ago before I new that they had previously been allowed
I had forgotten all about them again until just now.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 7/18/08, 7:41 PM
Hey Mark and Gerry, that is exactly the wiring in my own house.
The old 14/2 with ground conductor 16 gauge and all cut off at the jacket.
Some I was able to fix with the slack and some are not.
House was built in 1967. And the wiring romex is still the cloth fabric type. I forget the word for it already.
Marcel
