The panel is a split buss type, but the neutrals go through the middle of it. (first photo)
Can this cause overheating at the buss bar? (I know that the connection at the buss bar is incorrect) Peter |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like that panel is about maxed out... time for an upgrade
I always warn my clients about those cloth covered conductors.
Peter did you take a temp reading of the buss bar that has you worried? I do not like the way it looks either as they also can get in the way of the breakers. Quite a mix of types there by the way. Cloth Romex Bx Plastic (tin coated copper) Aluminum Copper www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 2/4/10 at 10:37 PM.. |
No wiring should cross over the buss bars, unless the panel is designed to allow so.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
I let them know exactly what I know.
The old cloth covered wires are very old and I recommend they be upgraded at some point. When being disturbed the covering is often brittle and falls off during normal work, such as changing outlets,light fixtures,switches,etc. When the brittle covering comes off ,it is often corrected with electrical tape that does not hold and shorting out of the wiring is a common event. This can be a real safety concern. Unlike Knob and tube wire it is not planned to be uncovered. |
| Opinion: Smoke Alarm Location | cevans | Interior Inspections | 10 | 6/16/09 6:31 PM |
| Main panel grounds & neutrals | jfrederick | Electrical Inspections | 15 | 3/1/09 10:04 AM |
| pole on double tapped neutrals | rdemott | Electrical Inspections | 10 | 11/16/08 10:49 PM |
| Neutrals | nbhi | Electrical Inspections | 8 | 8/9/08 1:10 AM |
| Split Buss CH panel w/Double tapped mains | gwilcox | Electrical Inspections | 5 | 7/18/07 7:14 AM |
