Todd Amundson is a non-member guest and is in no way affiliated with InterNACHI or its members.
I was wondering if you could install a VFD such as a wall mount fan into a GFCI outlet or are VFD's normally hardwired?
I've never seen a corded VFD. It could be just me since I've never seen a residential application/necessity for one. If there is one, it would probably chop up that sine wave enough to create a bit of electrical noise. It might cause the electronics in the GFI to read something's not right and trip it. How powerful of a wall fan do you have. Are you just trying to slow it down or just ease it up to full RPM?
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Yes, you can.
Can you post a link with some info or specs on a smaller VFD so I can look?
Jeff,
I found this info. It doesn't really answer your question but provides some insight. When a VFD starts a motor, it initially applies a low frequency and voltage to the motor. The starting frequency is typically 2 Hz or less. Starting at such a low frequency avoids the high inrush current that occurs when a motor is started by simply applying the utility (mains) voltage by turning on a switch. When a VFD starts, the applied frequency and voltage are increased at a controlled rate or ramped up to accelerate the load without drawing excessive current. This starting method typically allows a motor to develop 150% of its rated torque while drawing only 50% of its rated current. When a motor is simply switched on at full voltage, it initially draws at least 300% of its rated current while producing less than 50% of its rated torque. As the load accelerates, the available torque usually drops a little and then rises to a peak while the current remains very high until the motor approaches full speed. A VFD can be adjusted to produce a steady 150% starting torque from standstill right up to full speed while drawing only 50% current Andrew MacDonald MacDonaldPropertyInspections.com InsightThermalDiagnostics.com ITC/FLIR Certified Building Science Thermographer ITC/FLIR Certified Level 1 Thermographer |
Thanks, Andrew.
I've worked with them many times, but like I said I've never seen one for residential use. I'm just used to the larger VFD's for air handlers/chillers. 480V. Just looking for info on a smaller type. Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 2 | 1/8/11 8:04 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 10:24 AM |
