Hello All:
Spot the problem! THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
| Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like parallel ground feeds to the Grounding Bushing and twin taps again , 3 wires in the lug
White wire for ground wire was common 60 years ago . Those cloth covered wires are 60~ years old... Roy added Palallel wires to Grounds was common 60 years ago Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. Last edited by rcooke; 8/14/11 at 8:42 AM.. |
Good catch but that is not the biggest problem.
Great glad I missed some thing hope some else finds it .
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Are those 100 amp fuses on 6 AWG CU?
I will give a hint latter Roy!
Might it have something to do with the single white conductor in the bottom of the disconnect?
Think it is the Printing on the lable and I can not read it .. Roy Remember Green was always ground but Ground was not always green . Love these puzzels every body learns . I will give a hint latter Roy! Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Thanks I was not sure been out of the trade for about 30 years and the mind is getting slow and many changes I have not kept up with .
100 Amp panel.
Can you explain the entire setup? Is the panel downstream of this disconnect?
100 amp panel does not Matter this looks like 60 amp fuses.
The weakest link tells the size of the service so if they are 60 amp fuses it is a 60 amp service . ... Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Looks like it might be 100A panel with #4 Cu wires, but 60A fuses ... maybe even a 60A rated disconnect. Would be a 60A service ... but it looks like there is an elec range, and my guess would be an elec dryer also. Would have to do a load calc with actual house size and appliances to see if the 60A would be undersized. And agreed, need better pics
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 8/14/11 at 8:55 PM.. |
You can't focus your camera??
Try macro so we can all read it next time.. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Weird water heater problem | kweiss | Plumbing Inspections | 3 | 4/5/09 6:34 PM |
| cold spot showing in wall | Fran Walters | Thermal Imaging, Infrared Cameras & Energy Audits | 4 | 3/31/09 4:54 PM |
| furnace problem ? | Aaron lore | General Inspection Discussion | 11 | 2/5/09 1:04 PM |
| Internet browser problem | bking | Miscellaneous Discussion for Inspectors | 33 | 1/26/09 1:45 AM |
| I have a problem | cbottger | Electrical Inspections | 17 | 1/20/09 4:45 PM |
