Old 11/20/11, 12:32 PM
Stephen P. Shockley's Avatar
Stephen P. Shockley Stephen P. Shockley is offline
Default Can't figure out why the ground is connected to this faucet
In the attached image you can see a ground connection. The house was built in 1985 with all copper pipe. It has been renovated on the inside and there are GFCI's in all areas near running water. I couldn't determine where the wire was going or even why it was needed. Should I mention anything about this in my report or leave it alone? Could it be some sort of telephone line ground?
Thanks,
Steve
Shore-Footed Property Services, LLC
Stephen P. Shockley
MD Licensed Home Inspector
410-726-3471
Salisbury, Md
Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/20/11, 2:14 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Default Re: Can't figure out why the ground is connected to this faucet
Could be CATV or TELCO or something else. If you cannot determine what it is how will you write it up?
Old 11/20/11, 2:52 PM
Jim Port Jim Port is offline
Unmoderated Guest
If this is for the CATV or phone it should be bonded back to the system ground, not a random spot on the plumbing.
Old 11/20/11, 3:21 PM
Jeffrey R. Pope's Avatar
Whatever it is, it looks like a pretty ineffective connector. My guess would be for cable, satellite or telephone system.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/20/11, 5:12 PM
I guess I was wondering if I should mention the make-shift connection itself.
Stephen P. Shockley
410-726-3471
Salisbury, Md
Old 11/20/11, 5:18 PM
Jeffrey R. Jonas's Avatar
Agree on all points.
Old 11/20/11, 6:02 PM
This was a very common practice 15 years ago for CATV installations. Although it's incorrect by today's NEC standards it's better than nothing.
Old 11/20/11, 7:36 PM
Joseph M. Whitt Joseph M. Whitt is offline
Yes .
Mike Whitt
Contractor/Instructor
Counterfeit Copper Ground Rods ccurrins Electrical Inspections 2 5/28/11 4:52 PM
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 10:49 PM
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 10:23 PM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
