Should the red capped white wire be connected to the bar.
Thanks! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified Florida Home Inspector (and anywhere else in North America) |
It appears ( and I really can't tell in the image ) that it is spliced to another smaller white conductor which might go to the grounded terminal bar. Only you will be able to verify that as you were their. If the load was lets say 240V load with no neutral conductor needed then I guess they could cap it if they choose, if again no grounded conductor is needed in the circuit. Really depends on the circuit in question and what the picture does not tell us.
Paul W. Abernathy |
It appears the red wire or conductor terminates at the double breaker cut off at bottom of the picture.
Need more info. |
| Flat Roof Inspection Question - White Color | rrunnels | Thermal Imaging, Infrared Cameras & Energy Audits | 23 | 2/27/09 7:51 PM |
| When Chocolate City | klott | Miscellaneous Discussion for Inspectors | 28 | 6/23/08 8:12 AM |
