cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Interesting way to get a wire from the basment to the attic.
It is creative, but that's legal. That cast iron soil pipe is aparently abandoned. The romex is not required to be in a raceway. That soil pipe is being used as a convenient chase from the basement to the attic, aparently. No different than if you drilled holes in the top and bottom plates of the partitions and fished it through that way. My only concern would be that it doesn't pass hard over any sharp edges on the way in or out of that chase. Electricians sometimes use abandoned chimneys as a wire chase from the basement to the attic, particularly when the chimney has been torn down below roof level, and you have the open square hole in the attic as a path straight to the basement. You'd be silly not to take advantage of it.
Hi Mark, I agree, the biggest "criticism" I could come up with is the small amount of rain water that will run into the basement
Uh... how does that meet the support requirments for NM?
(B) Unsupported Cables. Nonmetallic-sheathed cable shall be permitted to be unsupported where the cable:
(1) Is fished between access points, where concealed in finished buildings or finished panels for prefabricated buildings and supporting is impracticable |
hum... "access point"
Maybe they installed a heated toilet seat??
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
My only concern would be a physical damage issue if the end of that cast pipe was rough.
Assuming it is not punching through the roof. If it is, you would have to call it a wet location |
Having once been a 24 year old, rehabbing my own buildings after a few years experience in construction, and looking back at 60 on the stuff I did then, I look at the same stuff during an inspection today, and wonder ... "what else?"
Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
| Download the videos here all about physics and electricity | jtedesco1 | Electrical Inspections | 5 | 9/14/08 3:58 PM |
| Handbook for Electrical Safety | pabernathy | Electrical Inspections | 1 | 1/1/07 1:14 PM |
| NACHI Chapters Free Electrical Training Available | jtedesco1 | Inspection Education & Training | 5 | 8/11/06 4:46 PM |
| Electrical Safety Information | jtedesco1 | Electrical Inspections | 0 | 2/19/06 1:48 AM |
