Old 10/27/08, 12:15 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Default What Causes This?
I had a living room outlet that has the top outlet controlled by a wall switch (for lamps). When I checked the outlet in the "on" position my tester checked OK. When the switch was turned off, my tester had a very weak (dim) light indicating an open neutral. Any ideas what would cause this indication? Thx.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 10/27/08, 12:19 PM
James F. McKee's Avatar
Default Re: What Causes This?
switch used to break white wire instead of black ???
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 10/27/08, 1:13 PM
Marc D. Shunk's Avatar
Banned
It's called capacitive coupling, and will occur with 3-wire cables. It's not a problem or a hazard. Just a phenomenon.
Old 10/27/08, 1:15 PM
David A. Andersen's Avatar
A bright light indicates the condition, not a dim one.
BPI# 5015804
Old 10/27/08, 1:23 PM
Michael Larson's Avatar
Get a Wiggy and remove the doubt.
Michael Larson
Hudson, WI
Old 10/27/08, 1:26 PM
Marc,
Capacitive or inductive?
Jeff
Old 10/27/08, 1:33 PM
Banned
Eh, probably inductive, in this case.
Do this experiment. Plug in the hot and neutral (white and black) of a 3-wire cable into a hot receptacle, then use a meter to check from the unconnected red wire to the white neutral. You'll get a voltage reading, and it can light up a neon lamp, such as are found in those plug checkers.
Old 10/27/08, 1:35 PM
That's the problem with high input impedance meters and neon light testers.
Because they put no load on the system they can give false or misleading readings.
Try troubleshooting vehicle wiring with a multimeter. Good luck.
Michael Larson
Hudson, WI
Old 10/27/08, 1:52 PM
Bob Elliott's Avatar
It is related to being able to light neon and flourescents with a high frequency tesla coil.
Inductive as Marc said.
