Old 8/13/09, 11:01 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Ceiling fan wiring...need info.
Is this ok...or should I recommend consultation with an electrician ?
My take is: should the wire be in conduit or behind the wall.
David
www.pyramid-home-inspections.net
Find an InterNACHI certified Tennessee Home Inspector (and anywhere else in North America)
Old 8/13/09, 11:32 AM
Jeffrey R. Jonas's Avatar
Default Re: Ceiling fan wiring...need info.
Acceptable in my area.
Old 8/13/09, 11:33 AM
Michael Larson's Avatar
If that is a listed wireway, I see no problem other than aesthetics.
Michael Larson
Hudson, WI
Old 8/13/09, 6:01 PM
Not something that appeals to everyone but it does have it place.
http://www.wiremold.com/www/consumer...al_raceway.asp
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 8/13/09, 6:19 PM
James F. McKee's Avatar
it's fine other than ugly David...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 8/20/09, 10:00 AM
I would not write it up because that wiring method is acceptable. However, I might question if the ceiling box is rated for the fan hanging load.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 8/20/09, 10:20 AM
Jim Port Jim Port is offline
Unmoderated Guest
If the ceiling box is not the sole support for the fan it does not need to be rated for fan support.
Old 8/20/09, 3:08 PM
lfoster's Avatar
lfoster lfoster is offline
Is the ceiling angled (as in cathedral) or is the fan swinging wildly ?
Old 8/20/09, 6:28 PM
Unmoderated Guest
Based upon the second photo the ceiling is sloped.
Old 8/21/09, 12:55 AM
Paul Pendley Paul Pendley is offline
Not the preferred method but as long as it conforms to the Manufacturers installation instructions then it should be ok.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 8/21/09, 5:40 AM
Martin A. Jorgensen Martin A. Jorgensen is offline
Very common practice and widely accepted in my location.
Old 8/23/09, 10:05 PM
True, but given the wiring method it is very likely that the box is the only support fotr the fan.
Frank P. Newman
Dublin, GA
Outside landscaping wiring on a manifold, need info. dnasser Electrical Inspections 2 2/10/09 9:37 AM
Top Ten Wiring Hazards Threaten Life and Property jtedesco1 Electrical Inspections 3 9/2/08 5:15 PM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
Vaulted Ceiling Insulation rcooke Canadian Inspectors 4 1/22/07 12:24 PM
