Old 6/27/08, 1:19 PM
Harry E. McClard's Avatar
Harry E. McClard Harry E. McClard is offline
Unhappy Challenger Panel
OK. Several issues for electrical guru but will keep it simple. Is this the "bad" Challenger panel? Wiring is a problem, outlet, etc, etc. Its predicessor is in the other picture. This was a home built in 1840 with so many levels of upgrades and additions over the years that I was having trouble keeping track of what was what.
Old 6/27/08, 5:56 PM
Jeffrey R. Pope's Avatar
Default Re: Challenger Panel
I've never heard that there are "bad" Challenger panels. I assume you're referring to design issues, or inherent problems with a particular panel or manufacturer.
Other than the grounding and grounded conductors sharing terminal screws, nothing sticks out as a problem in that panel.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/27/08, 6:03 PM
Brian E. Kelly's Avatar
Is the knob and tube wiring energized? That alone would get me to reccomend an Electrician.
Old 6/27/08, 7:58 PM
Thanks. I ran across docs that Challenger panel manufactured by FPE that was one of the "bad" ones. This one looked like Westinghouse (old and dirty label); panel itself looked ok though. No, the K&T has the wiring cut at the panel; all the insulators and stuff are still there though and there's a ton of the old wiring still strung around that had me a little leary at first, all dead though.
Old 6/28/08, 3:48 AM
Rollie Meyers Rollie Meyers is offline
Please Note: Rollie Meyers is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just FYI, the main breaker is a Zinsco/Sylvania design which BTW Challenger is a successor to, I would not loose sleep over it but just a sign that lowballers were at work.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 9:59 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
