| View Poll Results: Do you use a clamp meter? | |||
| Yes |
27 | 54.00% |
| No |
18 | 36.00% |
| What is a clamp meter. |
0 | 0% |
| Thinking about using one. |
5 | 10.00% |
| Voters: 50. You may not vote on this poll | |||
I would like to ask if you use an clamp meter what type do you use. There must be a dozen in Professional Equipment magazine.
http://metersuperstore.com/Merchant2...FSHyDAod1GwMDQ I would like to use for energy audits to determine power consumption. I figure I can use ohms law to convert amps/volts to power. Would also like to use for heat pumps/electric furnaces/panels. Also anyone know a good reference source for the proper use of the meter? An electrician friend of mine recommended a Fluke brand. He said get at least a 100 amp rated meter. I would think 200 amps would be needed. Thanks for your time and opinions. |
I use the Ideal 61-736. Rated for 400A. Costs about $100
Thanks Jeff
I hope the Ideal clamp meter is not like the ideal circuit analyzer. I have gone through 3 in the last 2 years. But they are good about swapping out with a new one. How often do you use yours? Lets say I am unsure of the main house amperage can the meter be used to determine main service amperage. Can you use this for electric furnaces? Thanks again. |
Hey David, I worked in a calibration lab for nine years calibrating all types of different meters. I would recommend Fluke over any other brand. They are solid, accurate, and can be calibrated if it ever needs it. I would stay away from Ideal, as they aren't very accurate and they cant be calibrated.
Hope that helps. HLC Home Inspections Okla. Lic. #776 I am licensed Realtor with Keller Williams. Office Phone # 405-691-2708
David, smaller clamp jaws come in handy to get in tight spaces (lots of wires).
To use; just clamp around one power leg and read the meter. You can set the meter at 200/400 (top range) and it measures anything above 1.0 amp. You may consider a combination volt/amp meter so you can do your figuring. You need to know both the volts and amps to figure watts. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Thanks guys appreciate the feedback.
Nope
It can be used on any circuit where you can isolate one of the ungrounded conductors. I use mine on almost all inspections, and even more so when there are indications of other issues. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
William
Did you answer no because the meter only measure under a load? Please explain no!! |
Jeff you posted right before I did. Thanks, explains the no answer.
Going to get one. What do you think of this product. Trying to decide for Inspecting and energy audits. https://www.wattsupmeters.com/secure/products.php |
Jeff elaborated on my short answer David. It can be useful with A/C season coming to check RLA on the outside unit.
David,
What does the $235 dollar unit do that this $25 one doesn't? http://www.amazon.com/P3-Internation.../ref=de_a_smtd He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Jeff,
I don't use one. Thinking about it though. Could you explain what you use it for on every inspection? Tom T & D Inspection Service
It can be used to check running load amps (RLA) of the outside A/C unit. RLA info is typically on the nameplate data.
gkay is a non-member guest and is in no way affiliated with InterNACHI or its members.
Quality, safety, true rms. This link takes you to flukes' ABC's of multi meter safety. Take the time to learn what makes a quality meter and how to use them safely. http://support.fluke.com/find-sales/...16_eng_h_w.pdf |
| Short circuit failures with 12/3 NM-B cable and NM clamp connectors | pabernathy | Electrical Inspections | 10 | 4/17/11 2:43 PM |
| 15% Off Moisture Meters | jmckenna1 | Thermal Imaging, Infrared Cameras & Energy Audits | 0 | 3/11/09 12:19 PM |
| Ground rod clamp | kmalone | Electrical Inspections | 10 | 11/12/08 11:42 PM |
| Does the ground wire need a clamp? | jkogel | Electrical Inspections | 7 | 10/9/08 6:30 AM |
| Noise from Meters?? | mlong | Electrical Inspections | 9 | 2/3/07 9:08 PM |
