Old 8/23/06, 8:19 PM
John Onofrey's Avatar
John Onofrey John Onofrey is offline
Default Clearance of primary to roof slope
I vebally advised my clients to check the survey for possible easement encroachment problems with this (see pictures). The pole was about 3 feet from the house and the transmission line was about six feet above the roof.
My experience tells me there should be an eight foot easement on each side of the pole. Don't know the proper clearance of the lines to the roof but I could have easily grabbed the line from the roof slope.
It doesn't look right. Haven't written the report yet. Any comments?
clearance-primary-roof-slope-primaryclose.jpg   clearance-primary-roof-slope-primaryclose1.jpg   clearance-primary-roof-slope-primaryclose2.jpg
John Onofrey Licensed Professional Inspector
Houston Home Inspection
Houston Home Inspector
www.texasinspectors.net
John Onofrey
President, Grail Media, LLC
"Effortless Email Marketing"
www.homehintsenews.com
2007 INACHI Inventions and Innovations Award Winner
Free! Inspector Email Marketing trial click here
Old 8/23/06, 8:23 PM
Dale Duffy's Avatar
Default Re: Clearance of primary to roof slope
John, I wouldn't want them babies laying on my home during a storm....
Something is wrong alright...
What was this a SELLERS inspection?.....
Old 8/23/06, 8:44 PM
New construction inspection, Houston Texas, Ashton Woods Homes.
I guess we all know clearance of service drops to this particular roof slope is three feet. Primary power rarely comes into play in our field however. There's just a wee bit more voltage involved here.
John Onofrey
Old 8/23/06, 8:50 PM
Unmoderated Guest
WOW!!
You have got to be joking me that that is new construction!
I was going to say the home looks pretty new, and ask which was there first, the home or the pole. From the sound of it the pole was.
The builder sounds like a buffoon for putting the house so close. I would agree that there MUST be some sort of easment or right of way along the path of those wires. And I'd bet dollars that it is more than 3'.
Like the others have said Michael, that chart doesn't have much relavance in this situation. Infact the NEC has no relavance. This is a POCO or municipality issue.
Old 8/23/06, 8:56 PM
Michael R. Boyett's Avatar
No, I realize that the graphic is not directly applicable but my thought was that if the existing lines violated any of those criteria then that would be a place to start. The higher voltage distribution lines certainly wouldn't have less stringent criteria associated with them. I'll delete the graphic so as to not confuse anyone.
Old 8/23/06, 9:02 PM
Mike,
I actually made that last post without seeing yours. I was probably typing when you were posting.
John Onofrey
Old 8/23/06, 9:45 PM
Jeffrey R. Pope's Avatar
Now that's just "fub-duck."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/24/06, 7:51 AM
No comments from the resident Sparkies? Must be over their heads (excuse the pun).
John Onofrey
Old 8/24/06, 9:17 AM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
John,
Houston local code from www.municode.com:
Sec. 10-32. Permit to construct--Required.
It shall be unlawful for any person to build, erect, or construct, or cause to be built, erected or constructed any building, structure or edifice for any use or occupancy whatsoever in, upon, over or across any easement, or any part thereof, granted to the city for sanitary sewer, storm water, water main, or electric line conduit purposes, or a combination of same, or upon, over, or across any privately constructed sanitary sewer, storm sewer, water main, or electric line conduit managed, supervised, or controlled by the city or connected with the sanitary sewer system, storm sewer system, water main system or electric line conduit system of the city when such person has actual or constructive notice of such privately constructed sewers, mains, or conduits, without first procuring a written permit to do so from the utility official.
(Code 1968, § 10-32; Ord. No. 90-635, § 24, 5-23-90)
The only problem is they do not list standard easement distances and this appears to be for buried lines (??). Most I have seen are generally 10 feet or better for any utility. You would need to check with the city on their easement amounts for overhead utilities and supporting poles.
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 8/24/06, 11:03 AM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
How but the issue of EMF? Electro-magnetic forces.
Cheers, Claude Lawrenson NACHI03121515
Inspection Support Services Inc.
"Those who can do. Those who CARE, teach" or
“Teaching is the highest form of understanding.” Aristotle
Old 8/24/06, 11:06 AM
I suppose the benefit would be getting free power through induction by installing several coils in the attic space!
John Onofrey
Old 8/24/06, 2:06 PM
dcameron1 dcameron1 is offline
John,
There are codes governing this type of problem. Do you know what the voltage is for the distribution line that is shown in your pictures? The voltage determines which of the codes would apply. I will be online this evening and will have looked it up in the code book, if you could reply, with the line voltage.
I have over 40 years of experience in the electrical distribution field and feel we can work to give an accurate report to your client.
Dale Cameron
Cameron Home Inspections
Brookfield, MO
Old 8/24/06, 5:37 PM
Patrick Bolliger's Avatar
WOW
I hope those are not 12,500 volt???
In Chicago those are in alleys next to buildings. The Squirrels use them for access ways to the neighborhoods.... ZZZZZAAAAAAPPP!!
Where are the ..."Electrical professionals" A.K.A. Sparkies (expression soon to be removed from my vocabulary)....
What did the electrician say when he got jolted by an electrical coil?
"DAM! That Hertz"
Sorry bad joke....
Old 8/24/06, 6:48 PM
Originally Posted by dcameron1
John,
I don't know the volatage. My guess is around 13,000volts. I sent the report to my client this morning and wrote it up like this:
Clearance of primary power distribution pole to structure is about three feet (picture 1). The clearance of the primary power distribution lines appears to be about six feet from the roof slope (picture 2). Inspection of primary power distribution lines is outside of the scope of a standard home inspection but the condition appears to be non-standard and in need of further due diligence by the prospective buyer. The verification of clearances of primary distribution lines is a function of the local power company. I recommend that you consult with the local power utility company to determine if the clearance of the primary power distribution in relation to the structure, conforms to their standards. Another place to obtain verification might be the code department at the local municipality. It is also possible that the structure encroaches upon the utility easement at the right side. I recommend that you check the property survey to determine the location of the utility easements and to determine whether or not the structure encroaches upon them.
John Onofrey
Old 8/24/06, 6:50 PM
Of course the builder told them it was checked and is okay. I told my client to have them put it in writing.
John Onofrey
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 1:21 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 2:19 AM
Service Drop Clearance Over Roof mlong Electrical Inspections 6 12/19/06 8:39 AM
