OK what is the code on Fluorescent lightning in a closet. I know it says 6" from the vertical plane of a shelf in a closet, but does that include a closed covered fluorescent light? I am away from the office so no access to my NEC so can someone paste for me the actual code?
Thanks In advance. Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
| Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
2008 nec:
Article 410 Luminaries (Lighting Fixture), Lampholders, and Lamps
Article 410.8 (B) Luminaries (Fixture) Types Permitted. Listed. The following types of light fixtures shall be permitted to be installed in a closet. Closets (Clothes and storage) eight ( square feet (0.74 mē) or larger one of the following type of light fixtures shall be installed: 1. A recessed incandescent fixture with a completely enclosed lamp operated by a wall switch. 2. A surface mounted or recessed fluorescent fixture with a completely enclosed tube(s) operated by a wall switch. 410.8 (C) Luminaries (Fixture) Types Not Permitted. The following fixtures are not permitted: 1. Surface mounted incandescent fixture with enclosed, partially enclosed or open bulbs. 2. Pendant Style 3. Lampholders Exception: Walk-in closets of larger area where no storage exists within forty (40) inches (1016 mm) in any direction of a vertical line extending from the floor to ceiling, away from the wall, incandescent fixtures with totally enclosed bulb(s) may be used. Said light fixtures shall be operated by a wall switch. |
So am I correct in calling out the builder who put the surface mounted florescent light directly above a 12" shelf ?
They are not actually going to do anything about it which all of us know so do you actually think of it as a hazard? "You Make the call" |
Does it have the required clearances?
Well that is my original question. The light is a surface mounted fluorescent light with a cover that has its ends directly over the closets shelves. /
Picture would be nice but I do not really see a issue if the cover is plastic.
Here is the closet storage area as defined by the NEC. The surface mounted fluorescent cannot be within this area unless identified for use within the space. If not in the area it would need to be a minimum of 6" above the shelf and 6" in from each edge and from the back of the storage area in the graphic.
| Duct Work insulation question | Rick Vollmer | Inspecting HVAC Systems | 9 | 4/16/09 8:05 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Need help with lightning rods | sspradling | Electrical Inspections | 20 | 3/23/06 9:11 PM |
