All good things come to those who wait....but it helps to stay busy while your waiting.... HyTek Home Inspections & InfraRed Imaging Services Kokomo Home Inspection Lafayette Property Inspection Logansport Home Inspection Noblesville Home Inspection |
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Multi-strand AL has no issues or concerns if installed properly.
Note; What is shown as being cloth covered (impregnated cloth) it is most likely Tinned Copper. Again no issue. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
There is a bigger issue then Tinned Copper in this picture!
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Kevin, would you like to share what you see?
an uninsulated neutral to the range
Mike Whitt Contractor/Instructor |
Correct
Also the black neutral goes across the bus bar between breaker and the sheathing is cut back too far.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 Last edited by kwood; 1/17/12 at 9:02 AM.. |
I would agree that it's tinned copper. It's likely that a 3-wire feeder was permitted to a range when this was originally installed. What size are the conductors?
The copper conductor in photo #1 looks like a factory jumper connecting the two bus bars together.
Robert this is not a general practice in Ontario. Can you explain this info.
I am not an Electrician so I need to see the allowance for this. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
That is a factory installed jumper. It would also not be a black neutral.
SE cable was allowed to supply ranges.
Thanks Robert!
Which panel has the copper jumper? THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
That was probably installed before I was born but it looks like it to me. If it's not copper SE then what is it?
| Aluminum Wiring: Please proof this new inspection article. | gromicko | Electrical Inspections | 11 | 12/7/09 4:32 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
| Proper Marr Connectors for Aluminum Pigtails | jskrypka | Canadian Inspectors | 5 | 3/25/07 10:41 PM |
