Old 12/31/10, 3:39 PM
Thomas R. Hession's Avatar
Thomas R. Hession Thomas R. Hession is offline
Default cloth covered wire
I am sure this is tccw but wanted to check in with the experts before I turn in my report. Appraisers office says this is a 1954 house but the site also says it 28yrs old so I am inclined not to trust this information.
Also I need help with this installation method of this type of surge suppressor.
thank you in advance
cloth-covered-wire-gedc0029.jpg   cloth-covered-wire-gedc0028.jpg   cloth-covered-wire-gedc0030.jpg
Tom Hession
HHH Home Inspection Services LLC
Pinellas Park, Fl.
312-371-5076
http://www.inspectorpages.com/thession
http://www.pinellasinspector.com/
http://www.facebook.com/pinellashomeinspection
Home, Health, Happiness
Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/31/10, 3:49 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Default Re: cloth covered wire
The double tap for the surge protector is NG. The condcutors should land on a two pole CB.
Each of the neutrals need to be terminated in a single hole in the neutral bar.
Those look like tin coated copper conductors as you've suggested. The tin keeps the copper from reacting with the rubber insulation. Since all of the other conductors appear to be Thermoplastic, a conservative estimate would be that those tinned conductors have to be at least 30 years old.
Old 12/31/10, 3:54 PM
Sean Fogarty's Avatar
Conservative indeed.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 12/31/10, 3:58 PM
You're right I meant 50 years old.
Old 12/31/10, 3:59 PM
Bob Elliott's Avatar
I always recommend a upgrade on cloth wire.
It gets brittle and poses a hazard over time.
Old 12/31/10, 4:10 PM
Thank you guys....your the best.
I guess the appraisers website was right that the house was a 1954 home.
Tom Hession
Pinellas Park, Fl.
312-371-5076
Old 12/31/10, 5:11 PM
Check the toilets if they are original inside the tank for age.
Old 1/1/11, 1:54 AM
Robert Ernst Robert Ernst is offline
The Electrician sitting next to me says that the stuff is ok and if you see any issues with it recommend an evaluation.
Old 1/1/11, 2:39 AM
The Electrician is not very good.
Old 1/1/11, 8:38 AM
You can assess his abilities from a comment on a Forum?
Old 1/2/11, 12:04 AM
Well he's got 20 years in the trade. Your the HI and he's the expert. A HI shouldn't recommend replacement of anything with out seeing a problem. There is no visible issue with the wire, and like I said if you see one a evaluation was recommended. The electrician can do destructive test like bending the wire 90 degrees to see if the insulation cracks, we can't.
Old 1/2/11, 12:17 AM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
I'm 50 years old and if you bend me 90 degrees, I'll crack.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
Proper Marr Connectors for Aluminum Pigtails jskrypka Canadian Inspectors 5 3/25/07 10:41 PM
