Old 2/22/10, 4:50 PM
Nick Gromicko's Avatar
Default Clothes Closet Lighting. Please proof this new inspection article.
Find a Home Inspector
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/22/10, 5:31 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Clothes Closet Lighting. Please proof this new inspection article.
You may want to include the graphic from Article 410 to illustrate the space restrictions.
Old 2/22/10, 5:40 PM
Rob London Rob London is offline
Graphics dept is already working on it
Researcher and Technical Writer, InterNACHI
Old 2/22/10, 9:37 PM
heck....I gave them a library educators graphics to emulate...get busy fella...lol
Paul W. Abernathy
Old 2/22/10, 9:40 PM
You do know however, nothing requires a luminarie in a closet.....so any illumination is a plus as long as it is compliant with the NEC.
Paul W. Abernathy
Old 2/22/10, 10:56 PM
Bob Elliott's Avatar
I use this....
Article 410 Luminaries (Lighting Fixture), Lampholders, and Lamps
Article 410.8 (B) Luminaries (Fixture) Types Permitted. Listed. The following types of light fixtures shall be permitted to be installed in a closet. Closets (Clothes and storage) eight ( square feet (0.74 mē) or larger one of the following type of light fixtures shall be installed:
1. A recessed incandescent fixture with a completely enclosed lamp operated by a wall switch.
2. A surface mounted or recessed fluorescent fixture with a completely enclosed tube(s) operated by a wall switch.
410.8 (C) Luminaries (Fixture) Types Not Permitted. The following fixtures are not permitted:
1. Surface mounted incandescent fixture with enclosed, partially enclosed or open bulbs.
2. Pendant Style
3. Lampholders
Exception:
Walk-in closets of larger area where no storage exists within forty (40) inches (1016 mm) in any direction of a vertical line extending from the floor to ceiling, away from the wall, incandescent fixtures with totally enclosed bulb(s) may be used. Said light fixtures shall be operated by a wall switch.
I add to never use metal pull chains on bare bulbs.
Old 2/22/10, 11:10 PM
William J. Decker's Avatar
YEAH. WHAT HE SAID!
Sorry, jus had to do it. Paul is my friend.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 2/23/10, 11:45 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Nick,
Thanks! I asked about this article on Sunday, and Nick said they would have something on Tuesday! This why INACH is the BEST!!
Thanks again!!!!!!!!!!!!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 2/24/10, 10:41 PM
Why?
Old 2/24/10, 11:52 PM
Originally Posted by rlondon View Post
Why?
The base cracks and conducts electricity to your body through the exposed socket..
I have seen so many cracked off in closets ,it is ridiculous, and easy for the chain to touch the base socket.
The hot should be through the center button, but the wire can be reversed.
Another factor is when the light is on the socket is hot anyway,even when wired correctly.
Did not read that,as it is just common sense .
Old 2/25/10, 12:14 AM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Right, that is why newer ones have a plastic 'separator' on them, so you don't get a zinger. I still can't believe people buy these nowadays but they do.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/25/10, 12:26 AM
Believe it or not I still find them in rehabs and new construction.
I always let them know how that top shelf and boxes is a bad combination ,till they change over to a florescent operated wall switch.
Closet lights not required so they just throw in a garbage light, most likely to open the closet doors and make the bedrooms look larger.
Old 2/26/10, 3:33 PM
Threw in something about that, thanks
Hard Water. Please proof this new inspection article. gromicko Plumbing Inspections 3 1/14/10 10:20 AM
Marijuana Grow Operations. Please proof this new inspection article. gromicko IAC2 Indoor Air Forum 0 7/21/09 3:48 PM
Roy the proof you asked for wdevries Canadian Inspectors 55 7/8/08 10:30 AM
Are electricians supposed to use these tools as per 70E? jtedesco1 Electrical Inspections 27 12/15/07 3:40 PM
Emergency Lighting (commercial) mcyr Electrical Inspections 24 6/10/06 10:06 AM
