Old 12/15/11, 1:26 PM
Jeffrey R. Pope's Avatar
Default Code Question
Can anyone provide me with a reference? I'm on an inspection and haven't had the opportunity to look this up yet.
What section/reference requires all conductors of a single circuit to be contained within a single conduit?
Thanks in advance.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/15/11, 1:41 PM
Michael Larson's Avatar
Default Re: Code Question
300.3 Conductors
• (B) Circuit Conductors Grouped Together.
All conductors of a circuit must be installed
in the same raceway, cable, trench, cord,
or cable tray, except
Michael Larson
Hudson, WI
Old 12/15/11, 2:40 PM
Thanks Mike.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/15/11, 8:08 PM
Jim Port Jim Port is offline
Unmoderated Guest
There is an exception for circuits run in non-metallic methods.
Old 12/15/11, 11:42 PM
Yes, I know. This was in two runs of side-by-side PVC, buried and supplying the pool equipment panel about 60 feet away.
I had never seen this done before, so I wanted to check the reference before I left the property. One PVC contained 1 ungrounded conductor and the neutral, while the other PVC contained the other ungrounded conductor and the EGC.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/16/11, 4:53 AM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
That is also a violation of 300.20(A).
300.20 Induced Currents in Ferrous Metal Enclosures or Ferrous Metal Raceways.
(A) Conductors Grouped Together. Where conductors carrying alternating current are installed in ferrous metal enclosures or ferrous metal raceways, they shall be arranged so as to avoid heating the surrounding ferrous metal by induction. To accomplish this, all phase conductors and, where used, the grounded conductor and all equipment grounding conductors shall be grouped together.
Old 12/16/11, 7:36 AM
Sean Fogarty's Avatar
To shed light on my ingonrance, with the exception of it not being code, what is the potential concern with running the wires in that manner?
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 12/16/11, 7:57 AM
Unmoderated Guest
The magnetic fields will cause heating.
Old 12/16/11, 9:41 AM
I read that, but didn't believe that to be at issue.
This was new construction, and the electrical inspector "assured" me this is acceptable after I questioned it. Based on the exception of 300.3, I conceded. After all, he does have the last word.
I didn't think 300.20 was at issue because the conductors don't really "travel through" separate metallic enclosures. I guess I can see the potential for a small portion of the box to become heated.
So (Robert and Jim), do you guys see this as an improper installation?
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/16/11, 9:56 AM
Unmoderated Guest
I would not do it this way and never thought about this before. I believe this meets the exception in 300.3. As far as 300.20, once the conductors enter the enclosure they could be considered grouped. I would like to hear other opinions on this.
Old 12/16/11, 4:22 PM
You're correct I quoted the wrong section It should be 300.20(B). 300.3(B)(3) directs you to 300.20(B).
300.3(B)(3) Nonferrous Wiring Methods. Conductors in wiring methods with a nonmetallic or other nonmagnetic sheath, where run in different raceways, auxiliary gutters, cable trays, trenches, cables, or cords, shall comply with the provisions of 300.20(B). Conductors in single-conductor Type MI cable with a nonmagnetic sheath shall comply with the provisions of 332.31. Conductors of single-conductor Type MC cable with a nonmagnetic sheath shall comply with the provisions of 330.31, 330.116, and 300.20(B).
300.20(B) Individual Conductors. Where a single conductor carrying alternating current passes through metal with magnetic properties, the inductive effect shall be minimized by (1) cutting slots in the metal between the individual holes through which the individual conductors pass or (2) passing all the conductors in the circuit through an insulating wall sufficiently large for all of the conductors of the circuit.
Old 12/16/11, 5:35 PM
Unmoderated Guest
Robert, as I understand 300.20 it would apply to things like K&T entering a metallic junction box or enclosure.
Old 12/16/11, 5:42 PM
Yes, but 300.3(B)(3) sends you to 300.20(B) which, in the case of the photo, would require a slot to be cut between the raceways. Since in the photo you have conductors run in different raceways then the provisions of 300.20(B) would apply.
Old 12/16/11, 6:40 PM
Unmoderated Guest
After reading both together I agree a slot is needed.
Old 12/16/11, 6:42 PM
Yes it's a bit confusing because when you read 300.20(B) as a standalone requirement it doesn't seem to fit the installation in question. Once you add 300.3(B)(3) into the mix it directs you to the requirement for a slot.
Cap and Trade: A License Required for your Home fcarrio Legislation, Licensing & Legal Issues for Inspectors 349 10/21/11 6:56 PM
Interesting Lawsuit Regarding Code Violations jbushart Legislation, Licensing & Legal Issues for Inspectors 1 3/19/10 2:26 PM
Fire Code Question rbennett General Inspection Discussion 2 6/8/06 8:13 PM
