Old 10/8/06, 7:14 PM
David C. Macy's Avatar
Default Code question
What year was it required to GFCI protect the light over the shower or bathtub. Was it in 2002 or 2005?
Thanks
Dave
Old 10/8/06, 7:55 PM
Jeffrey R. Pope's Avatar
Default Re: Code question
From what I see, it's not required. Only receptacle outlets require GFCI protection.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/8/06, 8:01 PM
Jeff
You are correct. I received a call from an electrician that corrected me.
I was under the impression it was a code. I admitted my error.
Now I know.
By the way. In a 2004 home is the water heater required to be bonded if it has plastic lines. Copper within 18" of the tank?
Thanks
Dave
Old 10/8/06, 8:10 PM
A water heater is not required to be bonded regardless of the piping. It's the piping that requires bonding (if it's metallic). The bonding jumper, seen at the water heater, re-establishes the bond after the piping passes through the water heater.
So to answer your question, there is no required bonding at the water heater, with non metallic piping.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/8/06, 11:57 PM
Bruce A. King's Avatar
No required bonding but an electric water heater must have a ground wire. It should also be installed where it is visibly evident without removing the small cover plate over the manuf's junction box.
If the code does not mention it specifically it would fall under the " install as per the manuf's specs "
Old 10/9/06, 1:07 AM
Paul W. Abernathy's Avatar
AHHH....thats why I hold a class called "Grounding and Bonding"....they often get confused and mixed up.
The Water Heater itself is required to be grounded...but not bonded...unless doing so meets the bonding requirement for piping likely to become energized....
ahh.. the mysterious bonded water monster......lives !
Paul W. Abernathy,CMI,CPI,CME
Home Inspector Listings jbowman Miscellaneous Discussion for Inspectors 225 10/18/11 7:54 PM
TSSA Issues Directors Order Adopting B149 Code Supplement Nalliah Thayabharan Canadian Inspectors 0 4/19/07 12:36 AM
Fire Code Question rbennett General Inspection Discussion 2 6/8/06 9:13 PM
