Old 10/13/12, 7:36 PM
Peter W. Bennett Peter W. Bennett is offline
Default Code Requirement for pigtailing Aluminum Wiring
Is there a code requirement to pigtail an electrical system with aluminum wiring?
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/13/12, 8:05 PM
Jeffrey R. Pope's Avatar
Default Re: Code Requirement for pigtailing Aluminum Wiring
No, there is not.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/13/12, 10:06 PM
Joseph Hagarty,  CMI's Avatar
The mix of Copper & Aluminum is a concern....
(older Split Main Panel)
code-requirement-pigtailing-aluminum-wiring-img_2546.jpg   code-requirement-pigtailing-aluminum-wiring-img_2544.jpg
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 10/13/12, 11:44 PM
Jim Port Jim Port is offline
Unmoderated Guest
Typically the breakers and bus bars were listed for use with both Al and CU.
Old 10/13/12, 11:52 PM
But not for copper and aluminum twisted together....
correct me if wrong........
Joseph P. Hagarty
Phone: 610-399-3675
Old 10/14/12, 9:04 AM
Unmoderated Guest
That would be correct Joe. I have seen reports where the AL was on a breaker and the suggested "fix" was to pigtail copper. This was an unnecessary step as the breaker or bus was already listed for use with the aluminum.
Old 10/14/12, 9:14 AM
Originally Posted by jpope View Post
No, there is not.
So when an electrician conducts the pigtailing, there's no code requirement?
The only guidelines would be the manufacturer's instructions on the package?
Old 10/14/12, 10:48 AM
Unmoderated Guest
Could you expand on why the pigtailing was requested?
Unless the devices are listed for use with AL there would need to be a method like pigtailing. The simple existence of AL does not require pigtailing. There are also devices that are listed for use directly connected to the AL.
Old 10/14/12, 10:53 AM
Chuck Evans's Avatar
The question asked was
The answer is no.
If you are asking does code apply if you do pigtail, which is an entirely different question, the answer would be yes.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 10/14/12, 8:06 PM
The answer is no.
Thanks Chuck.
What's the code requirement if an electrical does the pigtailing?
Old 10/14/12, 9:41 PM
Unmoderated Guest
It would need to be done in accordance with any listing or labeling requirements.
Old 10/14/12, 11:21 PM
Apparently, I misunderstood the question.
It is not required that AL wiring be pig tailed with CU - that's what I thought the question was.
If the AL is pig tailed with CU, the connectors must be appropriately listed, and used in accordance with their manufacturer.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Aluminum Branch Wiring update jshishilla Florida Inspectors 6 3/16/11 11:11 PM
1910 Build mcyr Electrical Inspections 12 8/1/10 1:41 PM
Garage/house fire door Steven C. Meyer General Inspection Discussion 15 2/5/08 7:06 AM
Aluminum Wiring jhagarty Electrical Inspections 23 10/5/07 2:56 AM
