"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com Last edited by nbhi; 7/8/08 at 9:41 AM.. |
What have you noted about it so far, Gary?
Moisture past or present.
Neutrals doubled with grounds. "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
No main breaker
It looks like a subpanel, which would not require a main.
At second glance, it looks like a split-bus. . .
dont forget the improperly marked white wire in the upper left side
What is the devise mounted on the right side of the panel . under the rats nest?
Other than that mass/mess of NM cables coming in that one sleeve, which I hate, and the things already mentioned, I can think of much else. Were grounding electrode conductors and/or water bonds present? |
Duh
Thanks for answering my dumb question Speedy. Did not even notice the neutral bar being buried like that. |
| Infrared Sample reports | dvalley | Thermal Imaging, Infrared Cameras & Energy Audits | 26 | 1/1/08 9:40 PM |
| For those in favor of licensing | gbeaumont | Legislation, Licensing & Legal Issues for Inspectors | 70 | 5/21/07 4:09 PM |
| Tidbits from the ASHI Message Board | jbushart | Miscellaneous Discussion for Inspectors | 124 | 4/27/07 12:05 PM |
