Old 3/6/10, 8:37 AM
Ralph A. Schade Ralph A. Schade is offline
Default Comments?
I'd like to get some feed back on the wiring in this panel. Done by an electrician.
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/6/10, 9:27 AM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Comments?
Except for the cables that are not properly secured I don't see much to comment on.
Old 3/6/10, 9:43 AM
Actually, I was hoping to get some comments on the wires passing behind the bus bars. Looks odd to me
Old 3/6/10, 11:28 AM
Joseph Tribuzio's Avatar
Joseph Tribuzio Joseph Tribuzio is offline
Do i see a double tap on the lower right hand side fuse second from bottom?
And whats with the two red wires going behind the block?
Joseph Tribuzio 708 453 8447
Tribuzio Home Inspection Services
CHICAGOLAND, ILLINOIS
www.thishomeinspector.com
ID# NACHI07062507
IL Lic#450.003128
Radon lic# RNIT2008216
Home Inspector Pro Software
HIP Web Hosting
Old 3/6/10, 12:33 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Still it looks cleaner than most panels from the 60's.
www.MauiHomeInspection.com
Old 3/6/10, 3:47 PM
Rick Marton Rick Marton is offline
Is that romex wires going through BX connectors?? Its hard to see. Rick
Old 3/6/10, 6:08 PM
I see double-taps. Some insurance companies here no longer insure a home with glass fuses.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 3/6/10, 8:09 PM
Thanks for the responses guys. I wrote up the double tapping and unsecured wires. I was hoping that a sparky could tell me if the red wires behind the bus bars is legal. My thoughts are that it is not and I wrote it up as non-standard installation and would like some verification of that. I've never seen a configuration like that. There were other electrical issues in the house as well and of course recommended that a qualified licensed electrician evaluate and repair the entire system as required.
Old 3/7/10, 11:16 PM
I'm not sure why the wiring behind the bus would be any different from wiring in front of the same bus area. I think either is OK for a HI point of view.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 3/8/10, 6:41 AM
conductors should not run across the bus front or back. Its not a safe practice.
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 3/8/10, 2:30 PM
Not to argue, but just playing "devil's advocate", why is is unsafe, how much clearance would there have to be to make it "safe", and is it a code or manufacturer's requirement?
Frank P. Newman
Dublin, GA
Texas Inspectors - new electrical comments kweiss Electrical Inspections 4 1/22/09 6:12 AM
Infrared Sample reports dvalley Thermal Imaging, Infrared Cameras & Energy Audits 26 1/1/08 8:40 PM
For those in favor of licensing gbeaumont Legislation, Licensing & Legal Issues for Inspectors 70 5/21/07 3:09 PM
Tidbits from the ASHI Message Board jbushart Miscellaneous Discussion for Inspectors 126 4/27/07 11:05 AM
