Old 6/21/06, 11:16 PM
hspinnler's Avatar
hspinnler hspinnler is offline
Please Note: hspinnler is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Comments on Panel
Arrow Hart division of Murray panel rated at 150 Amps. Two strands on bottom feed to 60 amp breaker were observed to be cut. How best to report? Thanks in advance.
ID:	4221   comments-panel-jarrell-inspection-029-small-.jpg.jpg
Old 6/21/06, 11:22 PM
Doug Edwards,  CMI's Avatar
Default Re: Comments on Panel
Not only were the cables trimmed to fit the connectors but that is one helluva bend they put in them too. First off trimming cable to fit is just plain wrong. Any reduction in the intended size of the cable reduces the ability of the conductor to effectively perform the way it was intended, can overheat, arcing, and the extreme bends further exacerbates the problem.
Old 6/21/06, 11:23 PM
Jeffrey R. Pope's Avatar
That's a split bus Hank (if you didn't know).
Many times you'll see the coductors cut or trimmed to fit into a breaker (which is wrong), but in this case, I think it would best be described as a "damaged" conductor.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/21/06, 11:24 PM
I see Doug beat me to the punch
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/21/06, 11:54 PM
hspinnler's Avatar
Two strong life lines you guys are. Thanks for the great comments. I did notice it was a split bus.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 8:28 PM
Old panel configuration for comments dnice Electrical Inspections 8 9/9/07 2:35 AM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 10:02 PM
Any Comments on this panel? hspinnler Electrical Inspections 19 5/28/06 8:41 AM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
