I've got a commercial inspection that I am doing next week. Did a site visit today, and have what is probably a basic question.
I know that sub panels should not have more than 6 breakers (throws) in general without having a "main" breaker in them. However there is/are main breakers, and I want to know if it's ok... Main Service enters in and is labeled as 800AMP service with a single breaker to shut off power to the whole building.My question is, since there is a single main outside, and each meter has its own shutoff, is there still a requirement that the sub panels have a shutoff too? Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
No.. |
This is incorrect. The "six-throw" rule applies to the service equipment.
Or a feeder to a detached structure.
The feeder requires a disconnect even if there are six or less breakers, does it not?
No Jeff. I am referring to NEC 225.33
Got it.
Ok, Got it. Thanks guys.
in a minimalist fashion it did
It did! That that was exactly what I needed. The additional info and correction was also well appreciated.
| Sub panel question | smcintire | Electrical Inspections | 2 | 4/13/08 10:20 PM |
| Panel Question | gmckenzie | Electrical Inspections | 9 | 8/24/07 2:25 AM |
| Electrical panel question | hziegenbein | Electrical Inspections | 7 | 3/17/07 3:11 PM |
| Service Panel question for board sparkies | pbolliger | Electrical Inspections | 8 | 5/14/06 10:24 AM |
