Old 6/24/06, 5:59 PM
cbarrows cbarrows is offline
Please Note: cbarrows is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Condominium Panel
Hey guys
I inspected a condominium town home (late 1980's) yesterday and the panel did not have a main disconnect nor a grounding conductor coming off the neutral bar. Also the dryer circuit was protected by 40amp breaker but the wire was awg10.
I assume that the main disconnect and grounding conductor are in a separate utility space with the meter.
Questions:
1. Would my assumption be correct? Is this a common arrangement for condos? If so how does bonding of hot and cold water pipes work in this case?
2. Is there some kind of exception to the rule for a dryer circuit that it can be overfused? I have seen this arrangement in a number of service panels lately.
Any advice is appreciated.
Craig
Old 6/24/06, 7:13 PM
Jeffrey R. Pope's Avatar
Default Re: Condominium Panel
1) Common for condos, yes. Bondinding of components is typically near the service equipment with jumpers at water heaters.
2) No exception for 240V dryer receptacles (that I am aware of). Paul?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/24/06, 7:26 PM
3 wire or 4 wire feeder?
Old 6/25/06, 8:11 AM
The feeder to the panel has 2 hot, 1 Neutral and a bare copper ground.
Old 6/25/06, 8:12 AM
Thanks Jeffrey.
Old 6/25/06, 11:09 AM
Jeff,
Yes, you are correct in that the grounding will take place at the FIRST point of Service Disconnection probably at the main panels location for the condo's in the mechanical room. I also suggest they make sure the proper wiring is to the " Remote Distrubution Panels" in the condo units themselves.
On the Dryer wiring, no exceptions on branch circuits for a # 10 AWG to be protected by anything other than a 30A breaker or smaller...in this example.
While smaller would most certainly cause a TRIP issue, you can't fix it by placing it on a larger breaker....ranges can be on 40 or 50A breakers in certain case...but not in regards to a 30A appliance as stated.
Paul W. Abernathy
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
