Old 6/28/08, 3:39 PM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Default conductors screwed to bus
Has anyone seen this done before?
The home main panel located in "attached garage" and remote panel in laundry was tapped into main bus bar.
Thanks in advance for input.
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 6/28/08, 4:00 PM
James H. Bushart's Avatar
Default Re: conductors screwed to bus
Definitely a moisture/corrosion issue in that panel.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 6/28/08, 4:04 PM
Unmoderated Guest
Those taps are certainly NOT compliant
Old 6/28/08, 4:18 PM
David P. Valley's Avatar
What a mess...defer it.
Old 6/28/08, 5:44 PM
Marc Benz Marc Benz is offline
Please Note: Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
That type of tap is not allowed and second thing is the moistore issue I really suggest have a electrician come out and have them check the breaker box very carefully and IMO I rather have that replaced anyway.
Merci,Marc
Old 6/28/08, 9:05 PM
wsiegel wsiegel is offline
not to mention ground and neutrals under the same screw
Old 6/28/08, 10:12 PM
Electrically it is a legal feeder tap assuming the other rules are followed BUT it is a listing violation in that panel unless the label says you can do it.
Some panels do allow lugging onto the bus but there are usually tapped holes on the bottom, listed for the purpose.
Old 6/29/08, 3:00 PM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
Notice the neutral connection/lug in the upper right hand portion of the picture...it looks as though that was added at the same time as the phase conductors.
I am very curious as to how that may have been performed...If you have other pictures, maybe you can post them.
What do you think? Can this work for you? jtedesco1 Electrical Inspections 21 2/26/11 2:00 PM
Where is it written.... bgromicko General Inspection Discussion 21 1/19/08 9:02 PM
Article 240 : Overcurrent Protection Article pabernathy Electrical Inspections 0 5/23/07 11:40 AM
Need Help from the Learned... gbrasseur Electrical Inspections 15 12/19/06 5:04 PM
