I inspected a house with an unfinished garage and there were some branch wiring (romex) running along the top plate (8 to 9 feet high)of the rafters. A few of the branch wires were run down the wall to an exterior mounted receptacle box. Does all the exposed wire need conduit or just the wire with in reach.
I don't know what the code is in Fl., but it wouldn't matter to me anyway. I would recommend for safety reasons that the wire coming down the wall be protected. As long as the wire above is out of the way and fastened correctly it would probably be fine.
Mark Jones Mark Jones Allmark Home Inspection Services Inc. Serving all of Northern Illinois, Vernon Hills, Libertyville, Gurnee, Fox Lake, Round Lake Phone: 847 651 2053 E-Mail: AllmarkInspect@aol.com www.AllmarkHomeInspection.com |
Conduit. Protects it from rodent damage.
An unfinished garage in Massachusetts doesn't require conduit protection, so long as it's properly secured. |
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Plus, it would probably take longer to do it wrong. |
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
No conduit here as long as it is properly secured and is wood framing. Rodents have nothing to do with it here.
It all comes down to whether it is "subject to physical damage" and that is always in the opinion of the AHJ. Most Florida AHJs want protection if it is below 6'6 or so but that is not written anywhere. There are NO local amendments in Florida, only local opinions.
I read this as running down the inside of the garage into the back of an exterior receptacle.
Am I wrong? |
Sounds hocky to me. Your description is too vague.
Is the NM being run through bored holes? Is the NM running along any 'surfaces'? Is the NM exposed to any possible 'realistic' physical damage? Photos please. tom |
That's the way it sounds to me Petey.
After reading it again I may be the one that don’t know how to read! |
In other words, Romex can be used under a deck as long it's properly secured. No sunlight. |
| Dwelling and Commercial Electrical Equipment | jtedesco1 | Electrical Inspections | 4 | 1/10/08 6:46 AM |
| Conduit as Ground | cbuell | Electrical Inspections | 12 | 4/16/07 6:18 PM |
| Should this be in conduit | kblair1 | Electrical Inspections | 18 | 12/26/06 4:50 PM |
| NACHI Chapters Free Electrical Training Available | jtedesco1 | Inspection Education & Training | 5 | 8/11/06 4:46 PM |
| Conduit | psmothers | Electrical Inspections | 2 | 6/3/06 12:05 PM |
