Old 3/26/06, 11:08 PM
Michael Peterson Michael Peterson is offline
Default Is this connection correct?
Hey everybody I have a question about these pics. This panel has 2 new breakers installed. The neutrals and grounds are connected in a wire connector with a pigtail comming off and going to the proper connection. Is this a problem or is it ok?
Thanks
Mark
connection-correct-3.jpg   connection-correct-4.jpg   connection-correct-5.jpg   connection-correct-main-panel.jpg
Old 3/26/06, 11:18 PM
royal12136 royal12136 is offline
Please Note: royal12136 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Is this connection correct?
Hard to tell in the picture, but with the double tapped breakers and general sloppiness, I would refer this to be evaluated by a qualified electrician.
Old 3/27/06, 12:23 AM
rmoore's Avatar
rmoore rmoore is offline
Please Note: rmoore is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't see any double taps (Square-D anyway).
Mark...theres no rules against wire-nuts or pig-tailing per-se, as in your photo. I would prefer to see the sheathing stripped away and the connections made further away from the exposed breaker lugs. Tough to call it "wrong" though.
PS...slightly larger photos would be nice next time.
Old 3/27/06, 8:10 AM
Bruce A. King's Avatar
Maybe we should start reporting panels "neatness grade"
I can see an issue where a panel is technically correct and the client is told by an electrician later that it is substandard work and needs a lot of work...
Of course this can happen with lots of things.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 3/27/06, 8:25 AM
rwand1 rwand1 is offline
I've seen neater work. Sloppy suggesting homeowner work.
Old 3/27/06, 8:58 AM
Roy D. Cooke, Sr's Avatar
Thanks
Mark
I can not see in the picture but if you have more then one neutral connected to a single neutral going to the buss then this could cause the neutral to be seriously overloaded.
Roy Cooke . Royshomeinspection.com
Old 3/27/06, 1:18 PM
Hey guys thanks for the input. I thought the same thing that it was ok just not desirable. Its always nice to get a second opinion. Thanks again.
Mark
Old 3/27/06, 1:52 PM
jwortham jwortham is offline
Please Note: jwortham is a non-member guest and is in no way affiliated with InterNACHI or its members.
I write these up but only in an advisory way.
The wiring inside the service entrance panel box has been very sloppily configured. This makes it difficult for anyone working on the panel to keep track of circuitry and is often the mark of work done by a do-it-yourself-er. I recommend having this cleaned up by a reputable licensed electrical contractor if work is done on the system in the future.
Old 3/27/06, 8:56 PM
On the double taps-- third picture, 3rd breaker down (looks to be a 220 breaker). Hard to tell if it is designed for this, I have not seen a breaker like that before.
If I am wrong I am sorry for the mistake.
Tim
Old 3/27/06, 9:24 PM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
Tim
Those would be piggy backed 120 volt single pole breakers. Two separate circuits. I believe that if one trips though that both are supposed to trip though.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 3/27/06, 10:45 PM
Square D made that twin breaker for some years, they are QO style. They are just like any other twin except they are side by side instead of stacked. They each trip individually.
Grounding rod connection from meter box fbartlo Electrical Inspections 37 7/28/07 12:30 PM
Correct connect at Furnace tmartens Plumbing Inspections 2 5/1/07 9:33 PM
Is this correct cpennick Electrical Inspections 4 6/15/06 10:15 PM
Tee Vent connection & dirt leg. dmacy Inspecting HVAC Systems 4 6/13/06 11:12 AM
