Are these GFCI protected receptacles considered inside the tub enclosure?
| Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
No but make sure they are GFCI protected.
I agree with Mike, not in the enclosure.
These are helpful:
Maybe this will help.
Note: the rules are different in Canada. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Peter,
Question.... where was the exhaust fan located? Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
in the toilet closet
I thought that might be the case by looking at the pictures. The reason I ask is to see how many inspectors would call that out. You now have a room that has a shower and a jetted tub with no exhaust fan for the moisture. Technically, by code, you don't need one if that window does open. But, who the heck is going to have that window open during the wintertime?
bschern is a non-member guest and is in no way affiliated with InterNACHI or its members.
Dang Strait they are! 3 feet easy... Ask yourself this? Would you let your kids bathe in there?
Here's one that was in the shower stall.
Please review the graphic posted in post #4 which shows receptacles and switches installed in a code compliant manner. Why would these receptacles be any different?
Is that an issue?
No parts to cause electrocution. |
| NEMA Enclosure Rating System | pabernathy | Electrical Inspections | 4 | 3/14/12 8:11 PM |
| Why was the Inside System sold/installed without FIRST identifying the problem(s) | john bubber | Structural Inspections | 0 | 2/20/10 6:14 AM |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Combustibles inside fireplace? | bmargiotti | General Inspection Discussion | 8 | 11/19/07 11:41 AM |
| Ground Wires Inside a Panel | mveitenhans | Electrical Inspections | 13 | 10/29/06 11:39 AM |
