Old 3/15/11, 4:58 PM
Gary T. Heller's Avatar
Default Copper/Alu same breaker
My comment in the report is as follows.
The 220 volt breaker feeding the water heater has both aluminum and copper conductors. This is not a common practice but these conductors are sized properly for the 30 amp breaker they are connected to and the breaker is rated for both copper and aluminum.
What say you?
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/15/11, 5:37 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Default Re: Copper/Alu same breaker
Are these in a raceway? What size is the Al conductor?
Old 3/15/11, 5:45 PM
Christopher Currins's Avatar
Kind of odd 2 separate types of conductors serving the same circuit outlet .
Christopher Currins
Certified, Licensed
Old 3/15/11, 6:05 PM
Jim Port Jim Port is offline
Unmoderated Guest
It might be a shadow but the CU looks larger than the AL. You also might have issues if all conductors of the circuit are not run together.
Old 3/15/11, 6:45 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
Well done Jim.
I was wondering who would catch this one.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 3/15/11, 7:21 PM
They are not in a raceway. The Copper is stranded and larger than the solid Aluminum.
Old 3/15/11, 7:45 PM
Jeffrey R. Jonas's Avatar
Screech..... <<<slamming on the brakes>>>
If that is actually 'solid' aluminum, now I have an issue with it. (Other than what was said above). That would be enough for me to call it out.
Are you sure? Looks like strand aluminum from here.
Old 3/15/11, 7:46 PM
Jeffrey Moore Jeffrey Moore is offline
what size are the wires as the Al should be larger if the copper is properly sized?
Is this a situation where the breaker has been changed at one time?
Jeff Moore
www.quantumhomeinspections.com
Flir (ITC) Level II Thermographer
Mesa, AZ
Old 3/15/11, 8:11 PM
The aluminum doesn't need to be larger than the copper. The copper is larger than what it needs to be. The aluminum needs to be one size larger than it would have to be if it were copper.
This is a fairly new Cutler Hammer panel. It appears to be proffessionaly installed on a home built in 1978. I cannot understand why anyone would use two differnet conductors. I stopped by the house today and did the panel and roof. I'm going back tomorrow to do the interior and the pool.
I appreciate all the comments. Jim...can you expand on the issues if the circuits are not run together?
Old 3/15/11, 8:39 PM
Unmoderated Guest
Article 300.3(B) requires that all conductors of the same circuit be run in the same raceway or sheath. Article 300.20 also applies where the raceway or enclosure is ferrous that the conductors be run together to avoid inductive heating.
Old 3/16/11, 1:04 AM
That is why I had in the question- if the Cu is properly sized, you did not state that the Cu was oversized
Jeff Moore
Mesa, AZ
Old 3/16/11, 5:00 AM
Since these are not in a raceway then one could conclude that they are in two separate cables which is a violation as Jim has outlined. With a limited exception stranded conductors in cables, (the copper one in this case) start with #8 and larger, which means that the copper conductor is likely #8. According to your last sentence quoted above, for a 30 amp circuit the Aluminum conductor would also be required to be a #8 since #10 copper would be the minimum for a 30 amp circuit for a water heater load. So is the Al conductor actually a #8 AL or is this quote from the OP incorrect?
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
Federal Electric 100A standalone main breaker -- OK or problematic? fbartlo Electrical Inspections 16 9/6/10 5:17 PM
Breaker Question mhawley Electrical Inspections 5 1/14/08 3:25 PM
Electrical Guru Question? Breaker lock outs pdoane Electrical Inspections 4 9/7/07 2:05 PM
Double Tapped Breaker tjohnson3 Electrical Inspections 8 4/20/07 9:04 AM
