at same grounding clamp. Is this dual rated?
| Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I don't know if the lug is rated for multiple conductors, but it appears you have tinned-copper rather than aluminum.
Thanks Michael, wanting to be sure this is not a connector I wasn't familiar with.
Jeff you're correct, it's tinned-copper. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
It's a moot point. The IRC and NEC prohibit GEC splices:
Do you have a photo of this installation? You need to be careful when determining what's actually a GEC and what's a bonding jumper. Only the GEC is required to be continuous. You can use bonding jumpers to interconnect all of the electrodes that are part of the grounding electrode system. Here's a few examples:
Yes that's a violation in photo #3. You have bare copper and tinned copper which is fine, however your splicing of the GEC is required to be irreversible. Also it is not permitted to use that lug in that fashion with two conductors. I see some other problems with the length of the SE cable to the panel on the left.
With photo at left (main panel) where bare copper and tinned copper is under same lug, that's also a violation, correct? Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Yes, here's the code references: Quote:
They do have one that is designed for Linking the grounds and they have a separator between each GEC. Never payed attention to the company name on them. Do you know Robert Meier?
You find it in encased situations in concrete. I think it is called a Servit. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
There are only two permissible types of products available to splice a GEC, one is an irreversible compression splice and the other is an exothermic welding (Cadweld) splice. I believe that you're referring to a split bolt that has a separator which would sit in between the two conductors. Those typically would be used when splicing aluminum and copper. That type wouldn't be required here since the to conductors are both copper nor permitted due to the only types allowed as previously mentioned. |
Correct. What is the name of the one I am refering to?
Electrical has always been my week spot in Home Inspection. The reason is I seem to not be able to wrap my head around the confusion as the wire # system. I have talked to electricians and they can't figure out why they did it this way either. Is there a reason? One more point Robert don't forget I am from Canada. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 Last edited by kwood; 7/31/11 at 8:38 PM.. |
Robert:
I know the name of that one. The one I am talking about has a separating shim in the middle that is used for two different size GEC's What is it called? One is split bolt single wire. The other is two wire. Same company but different name and application. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
| Light Switch Near Shower | vsantos | Electrical Inspections | 204 | 3/19/12 9:58 AM |
| Total galvanic reaction? | jtribuzio | Plumbing Inspections | 19 | 4/3/10 2:18 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
| Aluminum or tin coated copper wire?? | mlong | Electrical Inspections | 8 | 5/14/06 10:36 PM |
| Looking for comment by Caoimhín P. Connell | phinsperger | Ancillary Inspection Services & Additional Topics | 2 | 2/18/06 11:22 AM |
