Old 3/28/07, 4:05 PM
Jan Lombard's Avatar
Jan Lombard Jan Lombard is offline
Please Note: Jan Lombard is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Copper Tie in Electrical Panel
Hi - I'm not an electrician - Found this small copper tie in an electrical panel the other day - is this acceptable? - never seen it before
redhawkreports@yahoo.com
Old 3/28/07, 4:22 PM
tdietrich1's Avatar
Default Re: Copper Tie in Electrical Panel
IMHO:
No, it's poor workmanship, and terminal screws most likely not supposed to be used as anchoring points.
What I would do it comment about it, recommend it's removal at the next time an electrician services the system/panel. Was there any other stuff?
tom
Old 3/28/07, 5:29 PM
Peter Foxe Smothers's Avatar
Peter Foxe Smothers Peter Foxe Smothers is offline
How about a picture of the entire panel?
Foxe Smothers ( Owner / Inspector )
Pelican State Inspection
Your Best Choice for Home Inspection in the Shreveport & Bossier City Area!
www.PelicanState.Net
www.ShreveportHomeInspector.net
www.BossierCityHomeInspector.net
foxe@pelicanstate.net
LSBHI #10399
Old 3/28/07, 6:42 PM
Marc D. Shunk's Avatar
Banned
Originally Posted by psmothers
The wire sheathing should be removed so that it does not enter the panel more than 1/4". (Spelled it correctly this time JP )
Where'd that dimension come from?
Old 3/28/07, 7:09 PM
tdietrich1's Avatar
Dyslexia?
tom
Old 3/28/07, 7:51 PM
Unmoderated Guest
This is actually totally incorrect. It should read "no less than 1/4" ". I think this is what Marc is getting at.
You can leave all of it on if you want, but we typically do not.
Old 3/28/07, 7:52 PM
Unmoderated Guest
That copper twisty look goofy but I can not see how it is doing any harm.
Old 3/28/07, 8:14 PM
Whoops, a misinterpation of 312.5 (c) on my part. Thanks for the clarification.
LSBHI #10399
Old 3/29/07, 7:14 PM
Thanks for the repplies everyone - Here's the pics of the panel as asked by a memeber.
copper-tie-electrical-panel-starkrd-104.jpg   copper-tie-electrical-panel-starkrd-105.jpg   copper-tie-electrical-panel-starkrd-109.jpg   copper-tie-electrical-panel-starkrd-139.jpg
Old 3/29/07, 7:44 PM
New - still learning to spell!
Old 3/29/07, 8:08 PM
Banned
Nice Federal Pioneer panel. You're in Canada?
Old 3/29/07, 8:13 PM
Unmoderated Guest
It is amazing that they are nearly identical to our FPE, yet are not plagued with the FPacificE problems.
Old 3/29/07, 8:19 PM
Yep, from BC, Canada - no, not partcularly plagued as far as I know.
Old 3/29/07, 9:00 PM
Banned
It also looks like you potentially will have lots of overloaded neutrals on the multi-wire circuits. It appears they've got the black and red of the same multi-wire circuit hooked to the same twin breaker. Those twin breakers stab into one leg.
Old 3/29/07, 10:29 PM
Peter Doane's Avatar
Marc,
Can you explain? Forgive me in advance, just not following your post.
Peter Doane
NACHI ID# 05120681
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 10 5/21/07 3:01 PM
Electrical Safety Information jtedesco1 Electrical Inspections 0 2/19/06 1:48 AM
