Old 10/30/08, 9:32 PM
Ron Chorey II's Avatar
Ron Chorey II Ron Chorey II is offline
Default Is this correct
Inspected a home today and it looks like the grounds and neutral are tied together. Is this correct? This was a Cutler Hammer panel circa 1978 I think
Old 10/30/08, 10:06 PM
gbeaumont's Avatar
Default Re: Is this correct
Ronald, as this appears to be the panel containg the main disconnect having the Neutrals and grounds on the same bus is OK, however I would question the multiple tapping of the Neutrals, they really should be seperately terminated on the bus.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 10/30/08, 10:08 PM
GARY R. EVANS GARY R. EVANS is offline
It is fine as long as the house main breaker is in the panel. The neutral is required to be bonded to the enclosure at the main disconnect location. If the Main was outside by the meter then the the grounds and neutrals should be isolated from each other in the interior panel.
Old 10/30/08, 11:09 PM
tdietrich1's Avatar
The effort made braiding the wires to fit under one screw compared to using the empty screws ... tips me off to look closer at the electrical work. Common sense seems uncommon here.
Tom
Old 10/30/08, 11:30 PM
James F. McKee's Avatar
welcome aboard Gary....come back often....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 10/30/08, 11:32 PM
Regards
Gerry
agreed, but was this not a common practice Gerry???
Jim Mckee
Amherst, Ohio
Old 10/31/08, 2:44 AM
I think it was common in some areas of the country, but not in my area. I don't see double tapped neutrals or combined neutral-grounds all that often.
Old 10/31/08, 6:49 AM
David P. Valley's Avatar
Double lugged neutrals are a common practice here and I write every one of them up.
Old 10/31/08, 7:22 AM
Thank you gentlemen for your expertise
Old 10/31/08, 8:39 AM
gbeaumont's Avatar
Hi Jim, so was pushing 5 year olds up chimneys
but we think we know better these days
Seriously though, The code on double tapping neutrals came in in the early 1980's if memory serves, and the picture that was posted appears to feature quad & quin taps
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 10/31/08, 9:11 AM
Michael Larson's Avatar
It never has been permitted technically by UL67 and under NEC 110.3(B).
It was clarified in NEC 408.21
Even Mike Holt was confused by this issue.
Video link
Holt's comment:
Switchboards and Panelboards
408.21 Grounded Conductor Terminations
Intent: This new section should ensure that grounded (neutral) conductors terminate within the panelboard to an individual terminal. This has been a UL requirement (UL Std. 67 – Panelboard Standard) for some time, and the addition to the NEC is intended to bring this information to the installers. Technically, this is covered by 110.3(B), which requires all equipment to be installed in accordance with the manufacturer's installation instructions and markings, but nobody knew it existed. UL Std. 67 (Panelboard Standard) permits up to three 10 AWG equipment grounding conductors to terminate on a single terminal, if the terminal is marked for this purpose. Figure 408-3
The intent of this requirement is to ensure that the grounded (neutral) conductor of a multiwire branch circuit is not momentarily disconnected, which could result in the destruction of electrical equipment and fires from overvoltage.
Michael Larson
Hudson, WI
Old 10/31/08, 11:27 AM
Christopher Currins's Avatar
Here's another link that I include when I find double taps, All Burned Up
Christopher Currins
Certified, Licensed
Old 10/31/08, 1:53 PM
Video link
Holt's comment:
In 2005, this reference was moved to 408.41, for whatever reason. In case people are trying to search for it.
Jeff
Old 10/31/08, 1:59 PM
Jeff
That is correct.Thank you. The Holt video was discussing the 2002 NEC.
Michael Larson
Hudson, WI
Old 10/31/08, 2:05 PM
Joseph M. Whitt Joseph M. Whitt is offline
Video link
Holt's comment:
Michael
It is very important that the Home inspector understand that UL Standard 67 was a manufacturing standard and is/was not part of the listing and labeling of any panel board.
A copy of UL Standard 67 cost $1200 today and wasn’t much cheaper back in the 80s. For something to be part of the listing and labeling of a piece of equipment it must be furnished with the equipment when it is sold. It can not be something that is sold separately.
There are still panels that have sit on shelves for years that on the label will allow more than one grounded neutral under one screw. The code section was adopted in order to make all installation of both old and new panels.
Mike Whitt
Contractor/Instructor
Correct term gporter Inspecting HVAC Systems 3 2/26/08 9:29 AM
near correct condensate drain bking Inspecting HVAC Systems 2 9/19/07 1:51 PM
Correct connect at Furnace tmartens Plumbing Inspections 2 5/1/07 9:33 PM
First to answer this question substantially correct wins a NACHI Beam. $109 value. gromicko Miscellaneous Discussion for Inspectors 28 1/30/07 4:30 PM
Is this correct cpennick Electrical Inspections 4 6/15/06 10:15 PM
