Old 7/14/11, 9:49 PM
Brian M. OKeefe Brian M. OKeefe is offline
Default Is this correct?
Smaller diameter wires going into top of panel go to the smaller remote breaker for a/c.
Just does not appear to be a correct installation to me. Thanks in advance for your answers.
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/14/11, 11:10 PM
David Hays David Hays is offline
Default Re: Is this correct?
Brian,
Do you have any pictures of the feeder lugs on the 1st picture? From the angle of this picture it appears that the wires you are talking about are double lugged with the main feed wires. Unless the lugs are approved for double lugging it is not allowed.
David Hays
All Points Home Inspections LLC
Denver, CO
720-670-0366
allpointshomeinspect@yahoo.com
www.allpointshomeinspections.org
Old 7/14/11, 11:17 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is online now
Appears To be a double tap as well. I concur with David
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 7/15/11, 10:11 AM
Banned
Also the wires from the service wire terminals are not protected at all or protected by an oversized OCPD until they reach the breakered disconnect.
Old 7/15/11, 10:46 AM
Jeffrey R. Pope's Avatar
Agreed. Even if those lugs are rated for multiple conductors, the feeders shouldn't be tapped in before the service disconnect.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/15/11, 3:53 PM
Gregory A. Liebig's Avatar
Gregory A. Liebig Gregory A. Liebig is offline
I agree. Double tap at the service entrance is a no-no. There is no way to disconnect power to that sub panel. You didn't mention if the sub panel is bonded. That is another consideration to mention.
Greg Liebig, Owner
Sheboygan Wisconsin Home Inspector
4-Square Home Inspections, LLC
Where Knowledge will put your Mind at Ease ©
Sheboygan, WI 53081
(920) 451-4646
www.sheboyganhomeinspector.com
www.4squarehi.com
Like Us on Facebook
Follow Us on Linked-In
What is the correct way to write this up? mmeeker Miscellaneous Discussion for Inspectors 5 2/21/11 5:30 PM
Is the correct term for this type of roof rchorey Exterior Inspections 2 1/2/09 11:06 PM
Correct term gporter Inspecting HVAC Systems 3 2/26/08 9:29 AM
Correct connect at Furnace tmartens Plumbing Inspections 2 5/1/07 9:33 PM
First to answer this question substantially correct wins a NACHI Beam. $109 value. gromicko Miscellaneous Discussion for Inspectors 18 1/22/07 8:55 PM
