Old 10/23/08, 1:29 AM
Ron E. Perkerewicz Ron E. Perkerewicz is offline
Default correct roof penetration
is there a correct method (preferably in code) for electrical conduit to penetrate a flat roof. The problem is the pipe comes straight up to the heat pumps through the roof and the wire is run in an conduit stuck into it and caulked like crazy. I am looking for a standard that should be followed to install these
Old 10/23/08, 4:04 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: correct roof penetration
The pipe it sits in looks to have proper flashing (though aging)
The pipe makes for a solid pitch pan and as far as the silicone goes it may hold.
A premade boot would be what I would rather see though.
Here check out the site at this link.
http://www.bestmaterials.com/penetration_seals.aspx
Old 10/23/08, 9:34 AM
David P. Valley's Avatar
That particular penetration is improperly sealed (if it's sealed at all).
When applying EPDM (rubber material), the sheets of rubber are custom molded for the entire roof, so that rubber gets molded around the pipe itself or a rubber cup will get glued around the top of the penetrating area.
Like this...
Old 10/23/08, 9:42 AM
Barry Adair's Avatar
scroll down for example details
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/23/08, 9:59 AM
thanks everyone for the info
Old 10/23/08, 10:03 AM
Originally Posted by badair View Post
Barry,
Nice link with excellent illustrations.
I like this one...
Old 10/23/08, 3:01 PM
relliott's Avatar
Excellent site.
Go's straight to my saves.
Now if only they were all like that. (gotta stop answering late at night as my eyes missed it was EPDM)
Still think the hard pipe makes for a good pitch pan though.
Old 10/23/08, 4:14 PM
yep, nice to have the cut and paste links to add to reports to show how it should be done, when defects are identified
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 1/29/12, 12:20 AM
Jethro Bush Jethro Bush is offline
Please Note: Jethro Bush is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi, just stumbled across your thread. Check out www.tophatroofkits.com We use these roof penetration kits regularly and we neve have any roof leak issues. Regards
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 7:31 AM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 1:21 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 2:19 AM
