I believe the white seen in the recessed area of these breakers is some kind of corrosion. Can anybody tell me more about this?
Thanks. |
chunt1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
From the pic it appears to be dust/debris...similar to what is visible on the wires and everywhere else as well. Hard to tell.
Its not dust or debris. Its a white, chaulky substance in the slot across from the screw in the breaker. Its on all but one of the breakers.
Based on the fact that some of the 2 pole breaker ties appear to be rusted, it is pretty clear that a corrosive environment has existed in the panel at some point. However, from the picture, it pretty hard to tell if there is any corrosion that warrants any rehabilitation.
Frank P. Newman Emerald City Inspections, LLC Dublin, GA Last edited by fnewman; 5/6/08 at 3:43 PM.. |
It's not corrosion - I can't tell you what it is, but I believe it's something used during the manufacturing of the breaker. I see it all too often.
I'd be more concerned with the AL wiring. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
What did it taste like?
Just kidding. I have recently learned that some of the old breakers employed a borax plug in the arc chute for arc suppression. |
| Corrosion above furnace | dmacy | Inspecting HVAC Systems | 4 | 4/18/07 9:42 PM |
| Water heater corrosion - help please... | bwooddell | Plumbing Inspections | 6 | 2/10/07 7:17 PM |
| Water heater vent & corrosion to tank. | dmacy | Plumbing Inspections | 2 | 1/4/07 11:01 AM |
| Corrosion | dmacy | Plumbing Inspections | 4 | 12/27/06 10:21 PM |
| Soldered pipe supports causing corrosion | kshepard | Plumbing Inspections | 7 | 12/3/06 2:30 PM |
