Old 3/7/07, 5:02 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default corrosion at CU & AL
There were many issues in this panel, but I thought I would share this picture of the corrosion at the double copper/double aluminum ground wire connection.
Old 3/7/07, 5:32 PM
wsiegel wsiegel is offline
Default Re: corrosion at CU & AL
But it still works - what's your problem??
Old 3/7/07, 5:41 PM
tdietrich1's Avatar
Funny how it looks like a bad car battery terminal.
Many terminals don't have specs for doubling up grounds under one screw. So, it's not allowed per manufactures instructions. Also, the condition of the conductors warrant being deferred to a qualified electrician for evaluation/correction.
Just ugly.
tom
Old 3/7/07, 8:13 PM
Unmoderated Guest
That is not a reaction between the copper and aluminum. That is caused by WATER. I see it all the time.
See how the set screws are rusted.
Old 3/9/07, 4:20 AM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
And yet, aluminum is STILL not officially banned for branch circuit wiring.....ALCOA got friends in high places!!!!
Old 3/9/07, 6:54 AM
Unmoderated Guest
Do you seriously feel this way? If so then all aluminum should be BANNED from ALL electrical applications.
I see WAY more failures from aluminum parts and terminations than I have EVER seen from (larger) conductors!
It's funny though. Even though most folks have jumped on the AFCI bandwagon, I have the SAME opinion on them as your last statement.
Corrosion above furnace dmacy Inspecting HVAC Systems 4 4/18/07 10:42 PM
Water heater corrosion - help please... bwooddell Plumbing Inspections 6 2/10/07 8:17 PM
Soldered pipe supports causing corrosion kshepard Plumbing Inspections 7 12/3/06 3:30 PM
Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? jwatts1 Plumbing Inspections 8 7/29/06 12:50 PM
Water Pipe Corrosion inspector@carolina.rr.com Plumbing Inspections 6 6/12/06 6:37 PM
