Old 12/6/10, 7:51 AM
Kenny Rigler Kenny Rigler is offline
Default Couple Questions
Hey Guys-
The was on an old house that had been renovated. The service panel had 60 amp fuses that supplied power to two distribution panels. The first distribution panel had a 12 AWG red/blue/green conductor that supplied power to the detached garage. The red and blue were connected to individual breakers in which one was 20 and the other 25.
Should the two breakers be connected and is it okay that one is 20 and the other 25?
Part of the problem is also I was never able to see how the conductors were connected in the garage. It was finished and there was no visible panel or box. The service mast came down through the attic and went into the wall. Is is possible they used one of them to supply the lights and the other to supply the receptacles, but just used the same grounding conductor back to the panel? Just trying to figure out what exactly is wrong here and how to write it up.
BTW...I did catch the lack of a drip loop and the double-tap in the service panel but also interested if you guys write up the 60 amps service. Small two bedroom house but did have electric stove, range, and AC. Thanks.
Kenny
couple-questions-gedc0999.jpg   couple-questions-gedc1001.jpg   couple-questions-gedc1011.jpg   couple-questions-gedc0996.jpg   couple-questions-gedc1150.jpg
Rigler Home Inspections
Hays, KS 67601
785-656-0272
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/6/10, 8:56 AM
Joe Funderburk, CMI's Avatar
Default Re: Couple Questions
Undersized service. Double-tapped fuses in 2nd photo. Lack of a handle tie and improper breaker size...refer it all to an electrician.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 12/7/10, 5:08 AM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
This service is a mess. There are many violations here's a few:
-the green #12 grounded conductor
-the #12 is most likely not sunlight resistant
-the neutrals and EGC's must be separate at the sub panel
-lack of handle tie on MWBC
-no disconnect at second structure
-the doulbe tap
Old 12/7/10, 11:33 AM
Most insurance companies will not insure a home, at least here in the mid-west, with any service under 100 amp. Refer for full upgrade.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 12/7/10, 2:14 PM
Thanks guys...appreciate the comments.
Hays, KS 67601
785-656-0272
Old 12/9/10, 3:30 PM
Kenny, why are there 2 mast heads on the property? If the photo in pic 4 is a service entrance, it is improper: the mast head should not be below the point of attachment.
Theodore Roosevelt
Joe Funderburk, CMI
Old 12/9/10, 9:07 PM
The smaller one is feeding the garage.
Electrical Questions egriffin Electrical Inspections 10 1/28/07 11:57 AM
GFCI Questions egriffin Electrical Inspections 3 1/27/07 7:10 PM
