Does a CPVC water filter system need to be grounded? The system in question is a General Ionics product with a warning sticker in the main breaker panel of the home stating ( THIS HOME HAS A CPVC WATER SYSTEM WITH NO ELECTRICAL GROUNDS)
No...
The term would actually be "bonded," or "bonded" to the grounding electrode. But you cannot electrically-bond plastic components.
I would recommend removing it. |
I've seen all kinds Pete. . .
"No cold water bond" seems to be the most common in my area. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks guys, I appreciate the info.
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
